1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Subject: RE: To read single element from waveform record
To: "'Gofron, Kazimierz'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 27 Oct 2015 14:40:56 +0000
What you are seeing is a limitation of the default behavior of Channel Access with record fields of type DBF_STRING.  It is not a problem with the acalcout record.
However, EPICS base 3.14.11 added support for long strings over channel access, and the caput/caget/camonitor can now use it.  You need to add the -S option to the commands, and you need to append $ to the field name.
This is an attempt to write a 50 character string to the  .CALC field of an acalcout record using the default settings of caput
corvette:calc/calcApp/src>caput 13LAB:userArrayCalc1.CALC 01234567890123456789012345678901234567890123456789
Old : 13LAB:userArrayCalc1.CALC      0
New : 13LAB:userArrayCalc1.CALC      012345678901234567890123456789012345678
Note that it only wrote 39 characters.
This is a caput using the -S and $ settings:
corvette:calc/calcApp/src>caput -S 13LAB:userArrayCalc1.CALC$ 01234567890123456789012345678901234567890123456789
Old : 13LAB:userArrayCalc1.CALC$ 012345678901234567890123456789012345678
New : 13LAB:userArrayCalc1.CALC$ 01234567890123456789012345678901234567890123456789
Note that it wrote all 50 characters.
Now use caget with the default settings:
corvette:calc/calcApp/src>caget 13LAB:userArrayCalc1.CALC
Note that it only read back 39 characters.
Now use caget with the -S and $ settings:
corvette:calc/calcApp/src>caget -S 13LAB:userArrayCalc1.CALC$
Note that it read back all 50 characters.
-----Original Message-----
Sent: Tuesday, October 27, 2015 9:04 AM
To: [email protected]
Cc: Mark Rivers
Subject: Subject: RE: To read single element from waveform record
Mark,
The synApps that I am using is from 2013, and indeed the aCalcoutRecord.h has calc[80] set.
When database is created, the CALC has to be hardcoaded in the database, and seems to work for string longer than 36 char.
I tried to be set the aCalcoutRecord CALC value with caput and read it with caget. The field is truncated at about 38 chars when using caget/caput.
Kaz
Message: 4
Date: Mon, 26 Oct 2015 15:59:01 +0000
Message-ID:
	<[email protected]>
Content-Type: text/plain; charset="us-ascii"
Tim,
Regarding your post on extraction of single element from waveform:
http://www.aps.anl.gov/epics/tech-talk/2015/msg01340.php
The actual value of the CALC field is truncated from CALC, "a:=aa[0,0];b:=aa[1,1];c:=aa[2,2];d:=aa[3,3]
To
Any news on changing the length of the CALC field length to 80, as suggested in posts from 5 years ago?
http://www.aps.anl.gov/epics/tech-talk/2010/msg01574.php
Kazimierz Gofron
NSLS-II Controls Group
Brookhaven National Laboratory
(p) +1 (631) 344 5283
(f) +1 (631) 344 8085
(e) [email protected]<mailto:[email protected]>
(w) www.bnl.gov/nsls2<http://www.bnl.gov/nsls2>
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20151026/7da4326e/attachment.html>
Message: 5
Date: Mon, 26 Oct 2015 16:07:58 +0000
	<[email protected]>
Message-ID:
	<70AE7462E7AD054C89DCBA45343D499A659E4EAC@CARSMAIL2.CARS.APS.ANL.GOV>
This SVN commit suggests that CALC field length is indeed 80 characters since Sept. 2012:
r15207 | mooney | 2012-09-13 14:12:06 -0500 (Thu, 13 Sep 2012) | 7 lines
CALC fields are now 80-characters long
And the .h file reflects this:
grep calc ../../include/aCalcoutRecord.h ...
typedef struct acalcoutRecord {
        char            calc[80];       /* Calculation */
} acalcoutRecord;
What version of the calc module are you using?
From: [email protected] [mailto:[email protected]] On Behalf Of Gofron, Kazimierz
Sent: Monday, October 26, 2015 10:59 AM
Tim,
To
Kazimierz Gofron
RE: Subject: RE: To read single element from waveform record Gofron, Kazimierz
Prev: Re: theimagingsource cameras? Michael Davidsaver
Next: msi for windows IOC build ronaldo.mercado
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Subject: RE: To read single element from waveform record Gofron, Kazimierz
Next: RE: Subject: RE: To read single element from waveform record Gofron, Kazimierz
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
