Hi All,
I'm using CSS 3.2.16 with BOY. I have a script to write to some PV using writePV: timeout = 9 PVUtil.writePV("MyCam:cam1:Acquire" , 1, timeout) From the documentation, even if not super-explicit, I would assume the timeout is in s. The writing to PV usually works, but sometimes after a very long time I get a pop-up in CSS saying: "Failed to write PV:MyCam:cam1:Acquire Failed to connect to the PV in 9000 seconds. Reason: Failed to connect to the PV in 9000 seconds." This sounds like a bug. I will try changing the timeout from 9 to 0.009 in the script, but has anybody encountered this problem before? Thanks, Isabella
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
