Hi all,
Dear all,
A new major update of caQtDM (V4.0.0) is available for linux, windows, macOS and IOS . The IOS version 4.0.0 should be
available soon from the apple store..
This version has a major structure change: Now Control systems can be hooked to caQtDM by writing a plugin. The way you
can do that is shown by the demo plugin as well as by the epics3 plugin. A PV can then be prefixed with the plugin name the following way: epics3://pv. The default plugin is epics3 when no plugin name is given or an internal soft variable.
In summary:
caQtDM has now a controlsystem plugin structure. CS can be added by writing a plugin (see demo plugin) that will automatically be loaded.
By specifying the plugin in front
of the pv name (i.e epics3://somepv) that plugin will then be used.
fixed a small problem while writing a string to epics (could crash)
the build files have been simplified
edl2ui enhanced (by Lucas Carvalho)
several warnings (mainly on mac osx) solved
capolyline was not resizing correctly, this has been now corrected
a string containing a semicolon was only displayed up to the semicolon, this is corrected now.
cacamera and cascan2d got display of selected values and readback values with different representations and may therefore write values to the CS
soft variable bug corrected (was not always found when writing)
catextentry got input dialogs (filedialog in case of strings, otherwise simple dialog)
activ widgets were always brought in front. Now you can choose if you let the designer define the layer
QTextBrowser can be used with macro substitution. The file that will be read in, will be watched for changes and will automatically be reloaded
a vertical label has been implemented
You will find caQtDM on Github (https://github.com/caqtdm/caqtdm/) where you can also put issues and contribute as well. If you have any wishes please forward these to me directly or through
github.
It would also be nice if we would know about our users, so that we could setup a user list. Please send me your coordinates when you are using caQtDM.
Best regards
__________________________________
Paul Scherrer Institut
Dr. Anton Christian Mezger
WBGB/103
CH-5232 Villigen PSI
Telefon: +41 56 310 34 06
E-Mail: [email protected]
Re: Unable to build support modules on Windows, with base 3.15.2 Ben Franksen
EPICS Collaboration Meeting Andrew C. Starritt
<2015>
RE: Serial port COM10: not work? Heesterman, Peter J
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
