On 9/24/15 10:45 AM, J. Lewis Muir wrote:
>> If you succeed at building base, you'll encounter more problems when
>> you try to build other EPICS modules.
> Which problems are these? If a certain compiler does not build
> EPICS software correctly, it would be good to note that compiler as
> unsupported on Andrew's page.
I have not had a chance to document all of the problems I encountered
trying to build synApps_5_8 with Visual Studio Community 2015. Many of
the problems seem to be caused by Makefiles that unconditionally build
code that doesn't work on Windows, and therefore are a problem for all
versions of Visual Studio.
The sequencer is one module that is difficult to build on Windows, but
those problems have already been discussed here.
Kevin
- RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
- Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
- Re: Unable to build support modules on Windows, with base 3.15.2 Jani Hakala
- RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
- Re: Unable to build support modules on Windows, with base 3.15.2 Bob Soliday
- RE: Unable to build support modules on Windows, with base 3.15.2 Mark S. Engbretson
- Re: Unable to build support modules on Windows, with base 3.15.2 J. Lewis Muir
- Re: Unable to build support modules on Windows, with base 3.15.2 Kevin Peterson
Re: alarm severity set by other channel values J. Lewis Muir
<2015>
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
