1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Unable to build support modules on Windows, with base 3.15.2
To: "Peterson, Kevin M." <[email protected]>
Cc: "Engbretson, Mark S." <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 24 Sep 2015 09:25:57 -0500
AND the various commands scripts to initialize Softioc's and set paths for synapps modules used also imply that your actually doing this from inside a linuxy shell of some sort - I'm assuming Cygwin.
These pages really should say,  load these exact  versions of everything  required from locations that are not going to change so that when people build these things, they are all on exactly the same page . would reduce all the tech talk issues of people getting errors that no one else seems to see, because it is vague what the actual build configuration is.
I'd love to see Jenkins build of all the area detector stuff as well because , worse case, you just download all the bits that are already know to be working. If it would possible, would be nice to have some sort of virtual system, development environment - but can't really do that with Windows.  Ideally, cloning whatever Mark Rivers Uses as a development platform.
If someone is forced to use old versions of base, or odd configurations of synapps, they might be on their own more.  But is always annoying when you are trying some of this stuff on a fresh system and things don't work because the shakers and movers actually have some value added bits that don't get mentioned.
On Sep 24, 2015, at 08:55, Peterson, Kevin M. <[email protected]> wrote:
> On 9/16/15 3:46 PM, J. Lewis Muir wrote:
> Hi, Mark.
> Andrew has such a web page for EPICS Base at:
> http://www.aps.anl.gov/epics/base/win32.php
One of the problems with that web page is that you can read all of it
and still not know which version of Visual Studio you should use to
build on Windows.  It contains references to three different versions of
Visual Studio:
Visual Studio 2010 Express edition
Visual Studio 2012 Express edition
Visual Studio 2013 Express edition
The "Microsoft Visual Studio/C++ Express" download link contains a link
to download Visual Studio Community 2015, which will only build
base-3.14.12.5 if you know/remember to apply a patch from the known
problems page.  If you succeed at building base, you'll encounter more
problems when you try to build other EPICS modules.
The web page should recommend Visual Studio 2010.  This is the version
the jenkins build server currently uses to build EPICS base.  My
understanding is that it is also the version that is used to compile the
prebuild areaDetector support.
Kevin
Re: Unable to build support modules on Windows, with base 3.15.2 Ralph Lange
RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Re: Unable to build support modules on Windows, with base 3.15.2 Jani Hakala
RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Re: Unable to build support modules on Windows, with base 3.15.2 Bob Soliday
RE: Unable to build support modules on Windows, with base 3.15.2 Mark S. Engbretson
Re: Unable to build support modules on Windows, with base 3.15.2 J. Lewis Muir
Prev: Re: Unable to build support modules on Windows, with base 3.15.2 Kevin Peterson
Next: Re: Motor Record monitoring of Demand Value Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Unable to build support modules on Windows, with base 3.15.2 Ralph Lange
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
