1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: ADPerkinElmer R2-3 released
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "'[email protected]'" <[email protected]>
Date: Tue, 22 Sep 2015 19:38:44 +0000
Folks,
R2-3 of areaDetector/ADPerkinElmer has been released.
This release adds significant new functionality, and anyone using the Perkin Elmer amorphous silicon detectors should consider using the new version.
This is from the release notes:
R2-3 (22-September-2015)
* Added support for Data Delivered on Demand (DDD) mode.
  There is a new record PESyncMode which allows selecting the CameraTriggerMode.
  The most useful choices are "Framewise" and "DDD No Clear".
  Framewise was the only mode supported in previous versions of the driver.
  * DDD mode is required to use the XRPad models from Perkin Elmer, since they only have a single
    internal frame time, it cannot be programmed.
  * DDD mode fixes significant problems in earlier versions of the driver when ImageMode=Single.
    Previously with Single mode and TriggerMode=Internal the frame exposure actually started before
    Acquire was set to 1.
    This means it might include some time when motors were still moving or before a shutter was open.
    This is because the frame stream is constantly running, asynchronously to the acquisition command.
    It just grabs the next image after acquisition is started, which can happen anytime between
    0 and AcquireTime seconds after Acquire is set to 1.
    Previously this could be worked around by setting PENumSkipFrames=1, but this is inefficient.
    DDD mode allows synchronously collecting a single frame.
  * DDD mode fixes significant problems in earlier versions of the driver when TriggerMode=External.
    If trigger mode is run with PESyncMode=Framewise (the only choice in previous versions) then the
    actual acquisition time for each frame is the time between trigger pulses.
    If this is not exactly the same as the time that was used when collecting the offset images
    then the data quality will be poor.
    Setting PESyncMode="DDD No Clear" allows collecting for the time specified by AcquireTime on each
    external trigger.
    If the offset images were also collected for this time then the data quality will be
    good, even if the time between triggers is varying or is different from AcquireTime.
    Note however that DDD mode has an additional overhead, so the maximum frame rate is less than
    in Framewise mode.
    The overhead is about 0.2 seconds on the model 1621 in 2048x2048 (2K) mode,
    and about 0.1 seconds in 1K mode.
    The maximum frame rates are thus reduced from 15Hz to 5Hz in 2K mode and from
    30Hz to 10Hz in 1K mode.
    Framewise mode is thus still useful for fast triggered acquisition as long as the offset images
    are collected for the same time as the time between trigger pulses.
* The driver code was significantly rewritten to add the DDD mode support, make it simpler,
  and to add debugging information on calls to the XIS library.
Home page:
https://github.com/areaDetector/ADPerkinElmer
Release notes:
https://github.com/areaDetector/ADPerkinElmer/blob/master/RELEASE.md
Prev: Re: Sending PVs commands on multiple IOC at specific time Kasemir, Kay
Next: Wireless devices inside the accelerator tunnel Bob Gunion
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
