Hi Matt,
On 09/18/2015 03:48 PM, Pearson, Matthew R. wrote:
> I’m wondering why it’s convention that the ai record doesn’t use its convert
> function when using some types of device support routines. The analog value
> read function should return status=2 according to the IOC developers guide,
> and this causes it to not do any LINR type conversion on the VAL field.
The ai record reads raw data from the RVAL field which is a DBF_LONG,
i.e. a 32-bit signed integer. If an ai device support gets its input as
a floating-point value it is assumed that input processing such as
engineering units conversion has already been done, thus the 'cooked'
value it receives goes straight into the VAL field.
It is possible for device support to include code that implements some
of the input processing such as smoothing (recent versions of the soft
channel support do handle this), but making it do everything could
adversely affect performance. Floating-point operations are expensive on
some lower-end CPUs, thus the code was designed to avoid doing them
unnecessarily. The linear or slope conversion process does 2
FP-multiplies and 2 FP-adds, more if you use breakpoint tables and/or
smoothing.
> I’m wondering why I can’t do this:
> record(ai, "$(S):SE:CH1:PVRaw")
> field(DESC, "Process Variable CH1")
> field(DTYP, "asynFloat64")
> field(INP, "@asyn(n1,0,1)")
> field(SCAN, "I/O Intr")
> field(LINR, “SLOPE”)
> field(ESLO, “0.1”)
> whatever the device support routine passes to the ai record is what I get in
> VAL. So to do slope conversions I have to pass it to another ai record using
> soft channel device support.
You wouldn't want your 64-bit floating-point input data to be truncated
into a 32-bit integer after it has been read, so you don't want it to
have to pass through the RVAL field.
It would be permissible for the asynFloat64 device support to look at
the LINR field and do the additional processing you're asking for, but
it doesn't at the moment and that would be a little unusual. If someone
does add that code to Asyn, please examine the convert() routine in
aiRecord.c for what users normally expect to happen.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
-- Terry Pratchett, Reaper Man
- Re: ai record doesn't do convert for floats? Pearson, Matthew R.
- ai record doesn't do convert for floats? Pearson, Matthew R.
Re: ai record doesn't do convert for floats? nick.rees
<2015>
<2015>
