1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Unable to build support modules on Windows, with base 3.15.2
To: "'Heesterman, Peter J'" <[email protected]>, "EPICS Tech-Talk ([email protected])" <[email protected]>
Date: Tue, 15 Sep 2015 20:09:54 +0000
Hi Peter,
The errors appeared to be file permissions.  Do the permissions look OK in the module directory where you are building?  Is this the same location you have built previously with 3.15.1, or a copy in a new location?
My test yesterday was on a Linux file server in a tree shared with other builds (linux-x86_64, etc.).  I did the Linux builds first, so the O.Common directories were already built, etc.
Today I did a clean install on my Windows C: drive of base-3.15.2 and asyn-4-26 and both built fine with the windows-x64 architecture.
These are the first few lines of the build of asyn:
C:\EPICS\Support-3-15\asyn-R4-26>make
make -C ./configure install
make[1]: Entering directory 'C:/EPICS/Support-3-15/asyn-R4-26/configure'
perl -CSD C:/EPICS/base-3.15.2/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
make[2]: Entering directory 'C:/EPICS/Support-3-15/asyn-R4-26/configure/O.windows-x64'
perl -CSD C:/EPICS/base-3.15.2/bin/windows-x64/convertRelease.pl checkRelease
make[2]: Leaving directory 'C:/EPICS/Support-3-15/asyn-R4-26/configure/O.windows-x64'
make[1]: Leaving directory 'C:/EPICS/Support-3-15/asyn-R4-26/configure'
make -C ./makeSupport install
make[1]: Entering directory 'C:/EPICS/Support-3-15/asyn-R4-26/makeSupport'
make[2]: Entering directory 'C:/EPICS/Support-3-15/asyn-R4-26/makeSupport/O.windows-x64'
"Installing created executable ../../bin/windows-x64/makeSupport.pl"
mkdir ../../bin
mkdir ../../bin/windows-x64
"Installing ../../templates/top/Makefile"
mkdir ../../templates
mkdir ../../templates/top
"Installing ../../templates/top/configure/CONFIG"
mkdir ../../templates/top/configure
"Installing ../../templates/top/configure/CONFIG_APP"
From: Heesterman, Peter J [mailto:[email protected]]
Sent: Tuesday, September 15, 2015 12:13 PM
To: Mark Rivers; EPICS Tech-Talk ([email protected])
Hi Mark,
Thank you for having a look at this.
I’m still at a loss, it’s interesting that it works for you.
I’m using ActivePerl v5.16.3.
As it happens, I have both the 32 and 64-bit versions installed (same version).
This is unnecessary for the EPICS build - I can choose either  by altering the PATH to the Perl tools.
I note you are using the 64-bit version – I set my usage to match yours, but that didn’t make a difference.
Cheers,
Peter.
Sent: 14 September 2015 19:54
To: Heesterman, Peter J; EPICS Tech-Talk ([email protected])
Hi Peter,
I just tested building base 3.15.2 on windows-x64, and then building the support modules (seq, asyn, autosave, etc.).  It worked fine for me, I did not get the errors you did.
What version of perl are you using?
I am using ActivePerl 5.14.2.
C:\EPICS>perl --version
This is perl 5, version 14, subversion 2 (v5.14.2) built for MSWin32-x64-multi-thread
(with 1 registered patch, see perl -V for more detail)
Copyright 1987-2011, Larry Wall
Binary build 1402 [295342] provided by ActiveState http://www.ActiveState.com
Built Oct  7 2011 15:19:36
From: [email protected] [mailto:[email protected]] On Behalf Of Heesterman, Peter J
Sent: Monday, September 14, 2015 9:24 AM
To: EPICS Tech-Talk ([email protected])
Subject: Unable to build support modules on Windows, with base 3.15.2
I just downloaded EPICS base 3.15.2, superseding previous 3.15.1.
I am experiencing a problem building any of the support modules, while using the make file build.
(There is no problem building base 3.15.2 itself, however.)
I’ve built all the same code successfully on Linux, while using 3.15.2.
See attached, these are examples when trying to build Asyn or Seq, but this applies to all modules I’ve looked at, and to different build configurations I’ve attempted.
It all built OK when using 3.15.1.
What could I be missing?
Peter.
Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Prev: Re: Unable to build support modules on Windows, with base 3.15.2 Jani Hakala
Next: RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Next: Re: Unable to build support modules on Windows, with base 3.15.2 Jani Hakala
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
