Hi Till,
Thanks for labCA-3.5.0. I've built and tested it on windows-x64 and it mostly seems to be working. I get an odd message when I build:
C:\epics\R3.15.2\extensions\src\labca_3_5_0>make > make_labca_3_5_0.txt
process_begin: CreateProcess(NULL, sed -n -e "s/\(.*[^b]subsection.*[{][ \t]*\)\(lca[a-zA-Z0-9]*\).*/\2/gp" manual.tex, ...) failed.
And I may have a problem with the new lcaGetEnumStrings(). Here's what happens in matlab R2015a:
>> lcaGetEnumStrings('LTD-Q1D:Control')
Invalid MEX-file 'C:\epics\R3.15.2\extensions\src\labca_3_5_0\bin\windows-x64\labca\lcaGetEnumStrings.mexw64': The specified
procedure could not be found.
Steve
-----Original Message-----
Sent: Tuesday, September 08, 2015 12:56 PM
To: Gierman, Stephen; '[email protected]'
Subject: Re: building labCA on base 3.15.2, missing tsDefs.h
Yeah. tsDefs is cruft from the old days.
I just put up a new release (labca-3.5.0) which does away with tsDefs and TS_STAMP (replaced by epicsTime.h and epicsTimeStamp, respectively).
This release also features a new call 'lcaGetEnumStrings()' which allows you to retrieve the set of possible values for enum-type PVs.
Available as usual from
http://www.slac.stanford.edu/~strauman/labca/
- Till
On 09/07/2015 03:23 PM, Gierman, Stephen wrote:
> Hi,
> I'm building labCA (version 3.4.2) on base-3.15.2 for 64-bit windows. The build fails in the 'glue' directory when it cannot find the include file 'tsDefs.h'. Indeed, I do not find tsDefs.h in base-3.15.2, but I do find it in base-3.14.12.2, though it seems to be deprecated there. Here are the last few lines of the build:
> cl -EHsc -GR -DMATLAB_APP -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -I../../../../../base/include/compiler/msvc -I../../../../../base/include/os/WIN32 -I../../../../../base/include -I../../ezca -IC:\matlab\R2015a/extern/include -c ../ini.cc
> ini.cc
> ..\multiEzca.h(32) : fatal error C1083: Cannot open include file:
> 'tsDefs.h': No such file or directory
> make[2]: Leaving directory `C:/epics/R3.15.2/extensions/src/labca_3_4_2/glue/O.windows-x64'
> make[1]: Leaving directory `C:/epics/R3.15.2/extensions/src/labca_3_4_2/glue'
> I'm not sure what to do next ...
> Steve Gierman
- Re: building labCA on base 3.15.2, missing tsDefs.h Till Straumann
- building labCA on base 3.15.2, missing tsDefs.h Gierman, Stephen
<2015>
<2015>
