Hi Kay, [INFO] When I compile the CSS source code according your cssbook, I met some problems, could you please help me? My environment: Scientifc Linux 6(32), the latest eclipse, JAVA and CSS source code. I input these command: cd cs-studio-thirdparty; mvn clean verify P.S. During the process, I can always get access to the website. The following is the message: ********************************************************** [INFO] Reactor Summary: [INFO] thirdparty ......................................... SUCCESS [ 0.105 s] [INFO] thirdparty-plugins ................................. SUCCESS [ 0.004 s] [INFO] org.csstudio.platform.libs.jersey .................. FAILURE [ 0.260 s] [INFO] edu.msu.nscl.olog.api .............................. SKIPPED [INFO] gov.bnl.channelfinder.api .......................... SKIPPED [INFO] gov.bnl.unitconversion ............................. SKIPPED [INFO] org.csstudio.platform.libs.easymock ................ SKIPPED [INFO] org.csstudio.platform.libs.hibernate ............... SKIPPED [INFO] org.csstudio.platform.libs.jdbc .................... SKIPPED [INFO] org.csstudio.platform.libs.jfreechart .............. SKIPPED [INFO] org.csstudio.platform.libs.jmock ................... SKIPPED [INFO] org.csstudio.platform.libs.jms ..................... SKIPPED [INFO] org.csstudio.platform.libs.tine .................... SKIPPED [INFO] org.eclipse.nebula.widgets.grid .................... SKIPPED [INFO] org.eclipse.nebula.jface.gridviewer ................ SKIPPED [INFO] gov.bnl.shiftClient ................................ SKIPPED [INFO] thirdparty-features ................................ SKIPPED [INFO] org.csstudio.thirdparty.all.feature ................ SKIPPED [INFO] thirdparty-repository .............................. SKIPPED [INFO] ------------------------------------------------------------------------ [INFO] BUILD FAILURE [INFO] ------------------------------------------------------------------------ [INFO] Total time: 01:01 min [INFO] Finished at: 2015-09-08T06:15:37+08:00 [INFO] Final Memory: 98M/445M [INFO] ------------------------------------------------------------------------ [ERROR] Failed to execute goal org.eclipse.tycho:tycho-packaging-plugin:0.22.0:build-qualifier (default-build-qualifier) on project org.csstudio.platform.libs.jersey: No git repository found searching upwards from /home/lyx/forepics/cs-studio-thirdparty-master/plugins/org.csstudio.platform.libs.jersey -> [Help 1] [ERROR] [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch. [ERROR] Re-run Maven using the -X switch to enable full debug logging. [ERROR] [ERROR] For more information about the errors and possible solutions, please read the following articles: [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException [ERROR] [ERROR] After correcting the problems, you can resume the build with the command [ERROR] mvn <goals> -rf :org.csstudio.platform.libs.jersey Best wishes, Li Xing
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
