1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Select MS Bit from an integer
To: Andrew Johnson <[email protected]>, [email protected]
Date: Fri, 4 Sep 2015 14:01:29 -0700
On 09/04/2015 10:10 AM, Andrew Johnson wrote:
On 09/04/2015 11:12 AM, Till Straumann wrote:
You could do it with a bunch of calc (C1..C5, V) records
  C1 computes  (IN & 0xffff0000)
  C2 computes  (c1 ? c1 : IN ) & 0xff00ff00
  C3 computes  (c2 ? c2 : c1 ? c1 : IN) & 0xf0f0f0f0
  C4 computes  (c3 ? c3 : c2 ? c2 : c1 ? c1 : IN) & 0xcccccccc
  C5 computes  (c4 ? c4 : c3 ? c3 : c2 ? c2 : c1 ? c1 : IN) & 0xaaaaaaaa
V computes  (C1 ? 16 : 0) + (C2 ? 8 : 0) + (C3 ? 4 : 0) + (C4 ? 2 : 0) +
(C5 ? 1 : 0)
If I've understood this code properly V will be the bit number of the
highest set bit, from 0 through 31. It doesn't distinguish between no
bits set and only the LSB set though, you'd have to detect that separately.
Yes - depends on what the result should be. I just intended to present the idea.
The last line could e.g., be
IN ? (C1 ? 16 : 0) + (C2 ? 8 : 0) + (C3 ? 4 : 0) + (C4 ? 2 : 0) + (C5 ? 1 : 0) : -1
which would yield -1 if no bits are set.
The expressions could be simplified at the expense of more records
C1  = (IN & 0xffff0000)
C1C = C1 ? C1 : IN;
C2  = C1C & 0xff00ff00
C2C = C2 ? C2 : C1C
C3  = C2C & 0xf0f0f0f0
C3C = C3 ? C3 : C2C
C4  = C3C & 0xcccccccc
C4C = C4 ? C4 : C3C
C5  = C4C & 0xaaaaaaaa
If you have the synapps calc module installed a single transform record
could do all these calculations, transform handles up to 16 expressions.
You can find lots of bit-manipulation hacks at
     https://graphics.stanford.edu/~seander/bithacks.html
- Andrew
On 09/04/2015 07:59 AM, Dudley, David wrote:
Quick question that I didn’t see an immediate way to perform
How do I select the most-significant set bit in an integer?  I was
thinking about using a SEL, but that seems like a lot of work just to
do a simple thing.  Other possibility would be a SUB, but I’d like to
do it with base record types if I can.
Something simple please…
Select MS Bit from an integer Dudley, David
Re: Select MS Bit from an integer Till Straumann
Re: Select MS Bit from an integer Andrew Johnson
Prev: Spellman's Bertan 225 HV power supply James Rezende Piton
Next: OT: EPICS, Beer, and International Travel Ryan Pierce
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Select MS Bit from an integer Mooney, Tim M.
Next: Spellman's Bertan 225 HV power supply James Rezende Piton
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
