Good morning everyone,
In the UI I'm currently working on, I wanted to give the user the option to run a python script that will help with darkfield correction. In order to run the batch file, I'd planned on using either the caScriptButton or the caShellCommand; however, when directing the relevant fields to the batch file there was no result. I have tried the following: caScriptButton: No result 1) scriptCommand C:\\path\\to\\cmd.exe 'C:\\test.bat' scriptParameter No result 2) scriptCommand C:\\path\\to\\cmd.exe scriptParameter 'C:\\test.bat' Opened console with path set to location of .ui file; batch path not inputted 3) scriptCommand C:\\path\\to\\console.exe scriptParameter 'C:\\test.bat' ...other variations (including python.exe to .py script) caShellCommand: No result 1) files C:\\test.bat args No result 2) files C:\\path\\to\\cmd.exe args C:\\test.bat Opened console with path set to location of .ui file; batch path not inputted 3) files C:\\path\\to\\console.exe args C:\\test.bat Opened Notepad, printed out the contents from within the test.bat file 4) files notepad.exe args C:\\test.bat ...other variations (including python.exe to .py script) **All paths to the test.bat used quotes/no quotes interchangeably I'm still relatively new to the CAQTDM neighborhood, so any help would be appreciated! Best, -- Alex George Postbaccalaureate Fellow Imaging Physics Lab NHLBI, NIH Phone: (301)-741-0847
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
