Hi kay, I have some question about the css source code when I try to compile the css with eclipse. I failed several times, and no one knows about the error, could you please give me a favor? I use the CSS 3.2.16, SNS_Sources; linux is Scientific Linux 6; eclipse Eclipse for RCP and RAP Developers (32) error (5) : Description Resource Path Location Type PartStack cannot be resolved to a type OPIRuntimeDelegate.java /org.csstudio.opibuilder/src/org/csstudio/opibuilder/runmode line 339 Java Problem Description Resource Path Location Type The import org.eclipse.ui.internal.PartStack cannot be resolved OPIRuntimeDelegate.java /org.csstudio.opibuilder/src/org/csstudio/opibuilder/runmode line 58 Java Problem Description Resource Path Location Type The method detachView(IViewReference) is undefined for the type WorkbenchPage RunModeService.java /org.csstudio.opibuilder/src/org/csstudio/opibuilder/runmode line 246 Java Problem Description Resource Path Location Type The method getPane() is undefined for the type PartSite OPIRuntimeDelegate.java /org.csstudio.opibuilder/src/org/csstudio/opibuilder/runmode line 338 Java Problem Description Resource Path Location Type The method getStack() is undefined for the type PartPane OPIRuntimeDelegate.java /org.csstudio.opibuilder/src/org/csstudio/opibuilder/runmode line 339 Java Problem Thank you very much. Li,xing IHEP
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
