I recently changed the target platform of our custom CSS Tycho build such that it uses the "live" releases (instead of previously downloaded/compiled). When everything finally worked the target platform could be used for Eclipse and automated builds. So we got a build based on CSS 4.1.3. After a while (working on other branches) I discovered that the target platform does not resolve anymore: "Unable to locate installable unit org.csstudio.product.feature.feature.group 4.1.3" I checked the target platform in a text editor and found: <location includeAllPlatforms="false" includeConfigurePhase="true" includeMode="slicer" includeSource="false" type="InstallableUnit"> ... <unit id="org.csstudio.product.feature.feature.group" version="4.1.3"/> ... <repository location="http://download.controlsystemstudio.org/updates/4.1"/> </location> I found a new 4.1.4 version tag in the css repo on github and changed the above entry to: <unit id="org.csstudio.product.feature.feature.group" version="4.1.4"/> and it works. The Question is now: * Is it required to do this manually on each release ? (I added the target platform entry by entering the URL and just pressed "Select All") * Is there a way to continue building the "old" version ? Thanks Marcus
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
