Hi Ernest,
Good luck with testing, and if you find any issues, please let me know.
Sinisa
On 08/12/2015 10:01 AM, Williams Jr., Ernest L. wrote:
Hi Sinisa,
Thanks for your help.
By the way, using CONFIG_SITE.local does work.
I had a typo in there :(
So, no need to modify the source Makefile.
=== My CONFIG_SITE.local ==================================================
PACKAGE_AREA=/afs/slac/g/lcls/package
PYTHON_DIR=$(PACKAGE_AREA)/python/current
BOOST_DIR=$(PACKAGE_AREA)/boost/1.58.0/linux-x86
EPICS_HOST_ARCH=linux-x86
BOOST_PYTHON_LIB=boost_python
PVA_PY_CPPFLAGS=-DPVA_API_VERSION=440 -DPVA_RPC_API_VERSION=440 \
-I$(BOOST_DIR)/include -I$(PYTHON_DIR)/include/python2.7
PVA_PY_LDFLAGS=-L$(BOOST_DIR)/lib -L$(PYTHON_DIR)/lib -lpython2.7
Now, we start testing :)
Cheers,
Ernest
Sent: Wednesday, August 12, 2015 7:27 AM
To: Sinisa Veseli; [email protected]
Cc: Williams Jr., Ernest L.
Subject: RE: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope
Sent: Wednesday, August 12, 2015 6:51 AM
To: Williams Jr., Ernest L.; [email protected]
Subject: Re: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope
Ahh, ok. In this case, you probably used README file example, which
seems to be a bit out of date.
Could you try adding variables below in your CONFIG_SITE.local file, and
let me know what happens.
Sinisa
PVA_API_VERSION=440
-I$(BOOST_DIR)/include -I$(PYTHON_TOP)/include/python2.7
Sure, but there was no change.
Actually, I had to add your changes to the source Makefile
that is "<....>/base-cpp-R4-4-0-pre2/pvaPy/src/pvaccess/Makefile"
Looks like "CONFIG_SITE.local" does not get referenced by the Makefile.
So, I added the following to the Makefile and all is well now :)
====== src/pvaccess/Makefile snippet =====================
BOOST_DIR=/afs/slac/g/lcls/package/boost/1.58.0/linux-x86
PYTHON_DIR=/afs/slac/g/lcls/package/python/current
LOADABLE_LIBRARY_HOST += pvaccess
LOADABLE_SHRLIB_PREFIX =
#PROD_HOST_linux-x86_64 += testClient
PROD_HOST += $(PROD_HOST_$(T_A))
PVA_API_VERSION=440
CXXFLAGS += $(PVA_PY_CPPFLAGS)
CXXFLAGS += -g -I$(BOOST_DIR)/include -I/$(PYTHON_DIR)/include/python2.7
LDFLAGS += $(PVA_PY_LDFLAGS)
Compile is now successful:
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -g -fPIC -MMD -DPVA_API_VERSION=440 -DPVA_RPC_API_VERSION=440 -g -I/afs/slac/g/lcls/package/boost/1.58.0/linux-x86/include -I//afs/slac/g/lcls/package/python/current/include/python2.7 -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/afs/slac/g/lcls/epics/base/base-R3-14-12/include/os/Linux -I/afs/slac/g/lcls/epics/base/base-R3-14-12/include -I/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvDataCPP/include -I/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvAccessCPP/include ../StringUtility.cpp
/usr/bin/g++ -o pvaccess.so -shared -fPIC -Wl,-hpvaccess.so -L/afs/slac/g/lcls/epics/base/base-R3-14-12/lib/linux-x86 -L/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvAccessCPP/lib/linux-x86 -L/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvDataCPP/lib/linux-x86 -Wl,-rpath,/afs/slac/g/lcls/epics/base/base-R3-14-12/lib/linux-x86 -Wl,-rpath,/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvAccessCPP/lib/linux-x86 -Wl,-rpath,/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvDataCPP/lib/linux-x86 -m32 -L/afs/slac/g/lcls/package/boost/1.58.0/linux-x86/lib -L/python/current/lib -lpython2.7 pvaccess.o CaClient.o Channel.o ChannelGetRequesterImpl.o ChannelMonitorRequesterImpl.o ChannelPutRequesterImpl.o ChannelRequesterImpl.o ChannelTimeout.o FieldNotFound.o GetFieldRequesterImpl.o InvalidArgument.o InvalidDataType.o InvalidRequest.o InvalidState.o NtTable.o NtType.o ObjectNotFound.o PvaClient.o PvaException.o PvaExceptionTranslator.o PvaPyLogger.o PvA!
larm.o PvBoolean.o PvByte.o PvDouble.o PvFloat.o PvInt.o PvLong.o PvObject.o PvProvider.o PvScalar.o PvScalarArray.o PvShort.o PvString.o PvTimeStamp.o PvUByte.o PvUInt.o PvULong.o PvUShort.o PvUtility.o PyGilManager.o PyPvDataUtility.o PyUtility.o RequesterImpl.o RpcClient.o RpcServiceImpl.o RpcServer.o RpcTimeout.o StringUtility.o -lpvData -lpvAccess -lCom -lboost_python -lpthread -lreadline -lncurses -lm -lrt -ldl -lgcc
Installing loadable shared library ../../../lib/linux-x86/pvaccess.so
make[1]: Leaving directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-cpp-R4-4-0-pre2/pvaPy/src/pvaccess/O.linux-x86'
Cheers,
Ernest
From: [email protected] [[email protected]] on behalf of Sinisa Veseli [[email protected]]
Sent: Wednesday, August 12, 2015 5:27 AM
To: [email protected]
Could you please send me the output of the "make configure" step, as
well as the contents of pvaPy/configure/CONFIG_SITE.local file?
I created "CONFIG_SITE.local" and "RELEASE.local" manually.
The dependent packages required by pvaPy are installed from source in our environment.
We are not using a linux package manager for "boost" and "python"
*************** Output of make configure ********************************************************
[ernesto@lcls-dev2 pvaPy]$ make configure
cd tools/autoconf && ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... none
checking for python... /afs/slac/g/lcls/package/python/current/bin/python
checking for a version of Python >= '2.1.0'... yes
checking for a version of Python >=2.6... yes
checking for the distutils Python package... yes
checking for Python include path... -I/afs/slac/g/lcls/package/python/current/include/python2.7
checking for Python library path... -L/afs/slac/g/lcls/package/python/Python-2.7.4/lib -lpython2.7
checking for Python site-packages path... /afs/slac/g/lcls/package/python/current/lib/python2.7/site-packages
checking python extra libraries... -lpthread -ldl -lutil
checking python extra linking flags... -Xlinker -export-dynamic
checking consistency of all components of python development environment... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... none
checking for boostlib >= 1.40... configure: We could not detect the boost libraries (version 1.40 or higher). If you have a staged boost library (still not installed) please specify $BOOST_ROOT in your environment and do not give a PATH to --with-boost option. If you are sure you have boost installed, then check your version number looking in <boost/version.hpp>. See http://randspringer.de/boost for more documentation.
configure: error: required Boost library version >= 1.40.
make: *** [configure] Error 1
************** Output of CONFIG_SITE.local ****************************************************************************
[ernesto@lcls-dev2 configure]$ more CONFIG_SITE.local
PACKAGE_TOP=/afs/slac/g/lcls/package
PYTHON_TOP=$(PACKAGE)/python/current
BOOST_DIR=$(PACKAGE)/boost/1.58.0/linux-x86
PVA_PY_CPPFLAGS=-I$(BOOST_DIR)/include -I$(PYTHON_TOP)/include/python2.7
PVA_PY_LDFLAGS=-L$(BOOST_DIR)/lib -L$(PYTHON_TOP)/lib -lpython2.7
Cheers,
Ernest
Sinisa
On 08/12/2015 01:08 AM, Williams Jr., Ernest L. wrote:
I am working with EPICS V4 and would like to build the python support (i.e. "pvaPy")
HOST = RHEL5 32-bit, linux-x86
Indeed, I have configured/built the necessary dependent external packages
(1) Boost ==> 1.58.0
(2) Python ==> 2.7.4
The EPICS V4 release ==> base-cpp-R4-4-0-pre2
The EPICS BASE V3 release ==> base-R3-14-12
pvaPy"
All of the V4 modules build nicely, except that I have the following problem with "pvaPy"
Any help or solutions, appreciated:
../RpcClient.cpp:82: error: 'response' was not declared in this scope
======================= Compile Error Below ============================================
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -g -fPIC -MMD -g -I/afs/slac/g/lcls/package/boost/1.58.0/linux-x86/include -I//afs/slac/g/lcls/package/python/current/include/python2.7 -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/afs/slac/g/lcls/epics/base/base-R3-14-12/include/os/Linux -I/afs/slac/g/lcls/epics/base/base-R3-14-12/include -I/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvDataCPP/include -I/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvAccessCPP/include ../RpcClient.cpp
../RpcClient.cpp: In static member function 'static std::tr1::shared_ptr<epics::pvAccess::RPCClient> RpcClient::createRpcClient(const std::string&, const epics::pvData::PVStructurePtr&, double)':
../RpcClient.cpp:53: warning: no return statement in function returning non-void
../RpcClient.cpp: In member function 'virtual std::tr1::shared_ptr<epics::pvData::PVStructure> RpcClient::request(const epics::pvData::PVStructurePtr&, double)':
make[1]: *** [RpcClient.o] Error 1
make: *** [install.linux-x86] Error 2
Sinisa Veseli
Software Services Group
APS Engineering Support Division
Argonne National Laboratory
[email protected]
(630)252-9182
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
[email protected]
(630)252-9182
Sinisa Veseli
[email protected]
(630)252-9182
- Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope Williams Jr., Ernest L.
- Re: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope Sinisa Veseli
- RE: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope Williams Jr., Ernest L.
Job opportunity at PSI Kalantari Babak (PSI)
<2015>
LeCroy 1440 HV Support Jiro Fujita
<2015>
