This sounds like a problem with how you built your application. Did you put the correct entry in your application dbd file for your sequencer program?
Sent from my iPhone
On Aug 2, 2015, at 6:57 PM, Tasaddaq Khan <[email protected]<mailto:[email protected]>> wrote:
Hi Mark
I have run the st.cmd file and encounter an error:
#!../../bin/linux-x86/test
## You may have to change test to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","ioctest")
epicsEnvSet("TOP","/home/omar/epics/test")
epicsEnvSet("SNCSEQ","/home/omar/epics/seq-2.2.2")
epicsEnvSet("EPICS_BASE","/home/omar/epics/base")
cd /home/omar/epics/test
dbLoadDatabase "dbd/test.dbd"
test_registerRecordDeviceDriver pdbbase
## Load record instances
#dbLoadRecords("db/xxx.db","user=omarHost")
dbLoadRecords("db/test.db","user=omarHost")
cd /home/omar/epics/test/iocBoot/ioctest
iocInit
Starting iocInit
## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$
## EPICS Base built Dec 14 2014
## Start any sequence programs
#seq sncxxx,"user=omarHost"
seq snctest,"user=omarHost"
Can't find sequencer `snctest'.
Please guide how to solve this issue.
regards,
Tasaddaq
On Mon, Aug 3, 2015 at 3:12 AM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
You should not convert from .st to .c manually and then try to compile the .c. Rather you should just add the .st file to the source files in your Makefile and let the build system automatically convert the .c to .o using its rules.
Sent from my iPhone
On Aug 2, 2015, at 5:07 PM, Tasaddaq Khan <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
Hi
I converted my test.st<http://test.st><http://test.st> file to test.c file using snc but found following error while compiling the c file.
cc test.c -o test.o
test.c:7:21: error: seq_snc.h: No such file or directory
test.st:15<http://test.st:15><http://test.st:15>: error: expected ‘)’ before ‘seqg_env’
test.st:22<http://test.st:22><http://test.st:22>: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_event_volt_check_0_light_off’
test.st:22<http://test.st:22><http://test.st:22>: error: expected ‘)’ before ‘seqg_env’
test.st:23<http://test.st:23><http://test.st:23>: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_event_volt_check_0_light_on’
test.st:29<http://test.st:29><http://test.st:29>: error: expected ‘)’ before ‘seqg_env’
test.st:32<http://test.st:32><http://test.st:32>: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_chans’
test.st:39<http://test.st:39><http://test.st:39>: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_mask_volt_check_0_light_off’
test.st:42<http://test.st:42><http://test.st:42>: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_mask_volt_check_0_light_on’
test.st:47<http://test.st:47><http://test.st:47>: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_states_volt_check’
test.st:69<http://test.st:69><http://test.st:69>: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_statesets’
test.st:78<http://test.st:78><http://test.st:78>: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘test’
test.st:96:25: error: epicsExport.h: No such file or directory
test.st<http://test.st><http://test.st>: In function ‘testRegistrar’:
test.st:99<http://test.st:99><http://test.st:99>: error: ‘test’ undeclared (first use in this function)
test.st:99<http://test.st:99><http://test.st:99>: error: (Each undeclared identifier is reported only once
test.st:99<http://test.st:99><http://test.st:99>: error: for each function it appears in.)
test.st<http://test.st><http://test.st>: At top level:
test.st:101<http://test.st:101><http://test.st:101>: warning: data definition has no type or storage class
test.st:101<http://test.st:101><http://test.st:101>: warning: parameter names (without types) in function declaration
Any suggestion how to include the seq_snc.h in order to remove the problem. I can see seq_snl.h file in my include directory of seq-2.2.2
regards,
Tasaddaq
- seq_snc.h: file not found Tasaddaq Khan
- Re: seq_snc.h: file not found Mark Rivers
- Re: seq_snc.h: file not found Tasaddaq Khan
Leybold TD20 Pierrick M Hanlet
<2015>
<2015>
