Hi Mark I have run the st.cmd file and encounter an error:#!../../bin/linux-x86/test ## You may have to change test to something else ## everywhere it appears in this file < envPaths epicsEnvSet("ARCH","linux-x86") epicsEnvSet("IOC","ioctest") epicsEnvSet("TOP","/home/omar/epics/test") epicsEnvSet("SNCSEQ","/home/omar/epics/seq-2.2.2") epicsEnvSet("EPICS_BASE","/home/omar/epics/base") cd /home/omar/epics/test ## Register all support components dbLoadDatabase "dbd/test.dbd" test_registerRecordDeviceDriver pdbbase ## Load record instances #dbLoadRecords("db/xxx.db","user=omarHost") dbLoadRecords("db/test.db","user=omarHost") cd /home/omar/epics/test/iocBoot/ioctest iocInit Starting iocInit ############################################################################ ## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$ ## EPICS Base built Dec 14 2014 ############################################################################ iocRun: All initialization complete ## Start any sequence programs #seq sncxxx,"user=omarHost" seq snctest,"user=omarHost" Can't find sequencer `snctest'. On Mon, Aug 3, 2015 at 3:12 AM, Mark Rivers <[email protected]> wrote: You should not convert from .st to .c manually and then try to compile the .c. Rather you should just add the .st file to the source files in your Makefile and let the build system automatically convert the .c to .o using its rules.
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
