Hi I converted my test.st file to test.c file using snc but found following error while compiling the c file. cc test.c -o test.o test.c:7:21: error: seq_snc.h: No such file or directory test.st:15: error: expected ‘)’ before ‘seqg_env’ test.st:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_event_volt_check_0_light_off’ test.st:22: error: expected ‘)’ before ‘seqg_env’ test.st:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_event_volt_check_0_light_on’ test.st:29: error: expected ‘)’ before ‘seqg_env’ test.st:32: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_chans’ test.st:39: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_mask_volt_check_0_light_off’ test.st:42: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_mask_volt_check_0_light_on’ test.st:47: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_states_volt_check’ test.st:69: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘seqg_statesets’ test.st:78: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘test’ test.st:96:25: error: epicsExport.h: No such file or directory test.st: In function ‘testRegistrar’: test.st:99: error: ‘test’ undeclared (first use in this function) test.st:99: error: (Each undeclared identifier is reported only once test.st:99: error: for each function it appears in.) test.st: At top level: test.st:101: warning: data definition has no type or storage class test.st:101: warning: parameter names (without types) in function declaration
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
