1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: JCA 2.1.2 on 64 bit Ubuntu
To: Frank Gribbin <[email protected]>, [email protected], EPICS Tech-Talk <[email protected]>
Date: Fri, 17 Jul 2015 11:20:59 -0500
On 7/15/15 10:53 AM, Frank Gribbin wrote:
>     Does anyone have a version of JCA 2.1.2 on 64 bit linux?
Hi, Frank.
You probably have a reason for using JCA with the native EPICS
libraries, but just in case you didn't know, there is also CAJ which is
a pure Java implementation of CA.  If you were using that, you wouldn't
need to solve your current build problem.
Lewis
JCA 2.1.2 on 64 bit Ubuntu Frank Gribbin
Prev: Re: JCA 2.1.2 on 64 bit Ubuntu J. Lewis Muir
Next: Problems with building adPython plugin for area detector Alireza Panna
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: how NOT to update the record [SOLVED] Tasaddaq Khan
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
