1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: using motor / steppermotor record for Trinamic TMCM-351 controller
To: Christian Pauly <[email protected]>, <[email protected]>
Date: Wed, 15 Jul 2015 11:11:32 -0500
On 07/15/2015 03:20 AM, Christian Pauly wrote:
In the documentation of motor record, it says: "The following controllers are supported IN ADDIDION TO SOFT CHANNEL SUPPORT".
What is meant with this ?
"Soft Channel support" refers to EPICS device level support where there is no underlying hardware. All of the device support provided with EPICS base is some variation on "Soft Channel" device support.  For example, in the devSoft.dbd or softIoc.dbd files located in <base>/dbd you will find ;
devSoft.dbd:device(aai,CONSTANT,devAaiSoft,"Soft Channel")
devSoft.dbd:device(aao,CONSTANT,devAaoSoft,"Soft Channel")
devSoft.dbd:device(ai,CONSTANT,devAiSoftRaw,"Raw Soft Channel")
devSoft.dbd:device(ao,CONSTANT,devAoSoftRaw,"Raw Soft Channel")
The EPICS motor module also has Soft Channel device support. There is a tangent arm example here in the EPICS motor module document.
Ron
using motor / steppermotor record for Trinamic TMCM-351 controller Christian Pauly
Prev: JCA 2.1.2 on 64 bit Ubuntu Frank Gribbin
Next: Re: record to record ... Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: using motor / steppermotor record for Trinamic TMCM-351 controller Mark Rivers
Next: Prosilica GigE on MAC Hinko Kocevar
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
