On 15/07/2015 14:02, Benjamin Franksen wrote:
On Monday 13 July 2015 14:35:49 Kasemir, Kay wrote:
In principle, you can read include/link.h to get the 'record' pointer
of a link, cast that to the appropriate type, ...
But that's a bad idea because you'd directly access the memory of that
other record without it being locked.
It is possible to do this correctly, using the runtime database access
methods: in the init routine you call dbNameToAddr, store the address of
the dbAddr struct in the record's DPVT and in the subroutine place calls
to dbScanLock/Unlock around a call to dbPutField.
Note, though, that by doing this you are evading the lock-set mechanism,
which might get you into trouble - depending on your database configuration.
Records interconnected by links are put into a common lock-set to avoid
stack overflow situations with circular links. The described method
effectively creates a link that will be undetected by the lock-set
forming algorithm.
Obviously, disabling safety functions will not affect you in safe
situations, but...
Cheers,
~Ralph
- Re: record to record ... Ralph Lange
- record to record ... Stefen Paul
- Re: record to record ... Kasemir, Kay
- Re: record to record ... Benjamin Franksen
RE: using motor / steppermotor record for Trinamic TMCM-351 controller Mark Rivers
<2015>
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
