1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: SubArray
To: ishita bhatia <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Tue, 14 Jul 2015 11:21:33 -0500
On 07/14/2015 01:36 AM, ishita bhatia wrote:
> 72 bytes data is recieved in waveform record. Now i wan't to divide it
> in 2 subArrays(36 bytes). please suggest how to do that. I have tried
> the following:
> record(subArray, data1) {
>   field(SCAN, "Passive")
>   field(DTYP, "Soft Channel")
>   field(FTVL, "CHAR")
>   field(INP, "datavme.VAL")
>   field(MALM, "36")
>   field(NELM, "36")
>   field(INDX, "0")
>   field(FLNK, "vmehex1")
> It gives correct output :
> data1 36 53 51 -2 -19 127 -1 50 50 50 50 50 50 50 50 50 50 50 50 50 50
> 65 50 80 -14 50 64 70 -48 50 50 50 50 50 50 50 50.
> But for second subArray of 36 bytes what should I give values of MALM,
> NELM and INDX so that i can get next 36 bytes from waveform record.
To get to the second half of the input data the subarray record needs to
fetch the full array through the input link, so you must set MALM to 72,
but you only want it to export 36 elements so you would set NELM to 36,
and you want the first output element to start half-way through your
input array, so you set INDX to 36.
This is documented at
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_SubArray#Array_Parameters
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
SubArray ishita bhatia
Prev: Re: Conversion to Hexadecimal Rod Nussbaumer
Next: Re: Stepper Motor Controllers Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: SubArray ishita bhatia
Next: Re: SubArray Andrew Johnson
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
