1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: record to record ...
To: Stefen Paul <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 13 Jul 2015 14:35:49 +0000
Hi:
In principle, you can read include/link.h to get the 'record' pointer of a link, cast that to the appropriate type, ...
But that's a bad idea because you'd directly access the memory of that other record without it being locked.
Unless you really know what you're doing, it's much safer to use the standard `asub` (ex `genSub`) record and have its output links handle writing to other records.
-Kay
From: [email protected] <[email protected]> on behalf of Stefen Paul <[email protected]>
Sent: Monday, July 13, 2015 10:14 AM
To: EPICS Tech Talk
Subject: record to record ...
Hi
Just wanna know that if we have a 'sub' record then from its subroutine can we directly write into RVAL field of some other records say 'ai' records in the same database.
If the answer is yes then how does one get the address/pointer of other records (ai for example) in the subroutine of 'sub' record ?
Stefen.
Re: record to record ... Benjamin Franksen
record to record ... Stefen Paul
Prev: record to record ... Stefen Paul
Next: RE: record to record ... Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: record to record ... Benjamin Franksen
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
