1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: new version of STAR EPICS VM (now with Scientific Linux 6 and caQtDM)
To: EPICS tech-talk <[email protected]>
Date: Thu, 9 Jul 2015 14:43:38 -0500
I have just updated the STAR EPICS VM Environment to a new version.  I have long debated to do any major work on the EPICS VM environment, but there seems to be some demand (as I get a request for login info every now and then).  Combined that and some other internal reasons, I decided that it is worth creating a new version.  So, here it is.  Anyway it is available at the following URL:
http://physicsweb.creighton.edu/jiro/VirtualBox/ver6_index.html
It now uses Scientific Linux 6.6 (32-bit) with EPICS Base 3.14.12.5, Sequencer 2.2.2, Asyn 4.26, MEDM 3.1.9, EDM 1.12.99, caQtDM 3.9.4, Probe 1.1.8.0, VDCT 2.6.1274, Strip Tool 2.5.17.0, and StreamDevice 2.6.
Most significant is an addition of caQtDM (as I wanted to look into using caQtDM).  Those of you who has been using the previous version (with Scientific Linux 5), the login information is the same on this version.  I have done some testing, and everything I have tried so far seems to work.
I have also given a bit more disk space on the VM, so you can do more than what the old version used to do.  Of course, that means that the disk requirement on the host OS is bit higher now than before...  The old version is still available where it always have been.  So, feel free to use that one, if you must.
Cheers,
Jiro
Prev: Sequencer on Windows: co-maintainer needed Benjamin Franksen
Next: building tpmac on Windows Kevin Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Sequencer on Windows: co-maintainer needed Benjamin Franksen
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
