hi, all: I want to use cothread to write array data to a waveform record, but can't find how to do this. In the manual of cothread as following: Writes values to one or more PVs. If pvs is a single string then values is treated as a single value to be written to the named process variable, otherwise pvs must be iterable, and unless repeat_value=True is set, values must also be an iterable of the same length in which case values[i]is written to pvs[i]. Otherwise, if a single value is given or if repeat_value=True is specified, values is written to all PVs. seems can only get array data, can't write array data? thanks a lot in advance.
Best wishes
Geyang 2015-07-09
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
