1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS TCP server
To: <[email protected]>
Date: Mon, 6 Jul 2015 17:38:25 -0500
On 07/06/2015 05:30 PM, Mark Rivers wrote:
> I meant to say that your st.cmd contains these 2 lines:
> epicsEnvSet "P" "$(P=testIPServer)"
> dbLoadRecords "db/testIPServer.db", "P=$(P)"
> The first line is the one with the error.  My original reply had the wrong second line.
> Mark
> ________________________________
> From: Mark Rivers
> Sent: Monday, July 06, 2015 5:22 PM
> To: yann stephen; [email protected]
> Subject: RE: EPICS TCP server
> That does not look correct to me.  I think the first line should be:
> epicsEnvSet "P" "testIPServer:"
There may be a good reason why Yann is using macLib's default value
syntax, in which case the correct line should probably be:
epicsEnvSet "P" "$(P=testIPServer:)"
Mark's point that the trailing colon is missing is probably why your
channels aren't connecting; the macLib syntax should not be an issue.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
EPICS TCP server yann stephen
RE: EPICS TCP server Mark Rivers
Prev: RE: EPICS TCP server Mark Rivers
Next: streamdevice redirective problem Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
