Subject: |
setting NTP time sync interval on vxWorks |
"Zhang Yuliang" <[email protected]> |
To: |
tech-talk <[email protected]> |
Date: |
Fri, 3 Jul 2015 16:36:10 +0800 (GMT+08:00) |
Hi all,
I want to know how to set the NTP time sync interval on vxWorks. The output of "NTPTime_Report 1" shows the default interval is 60 seconds:
timingMain>NTPTime_Report 1
NTP driver is synchronized with server
Syncronization interval = 60.0 seconds
Last synchronized at 2015-07-03 16:06:19.062927
OS tick rate = 60 Hz (nominal)
Measured tick rate = 60.007 Hz
NTP Server = 10.1.201.31
value = 0 = 0x0
I can modify the variable "NTPTimeSyncInterval" in file $(EPICS_BASE)\src\libCom\osi\osiNTPTime.c to change the sync interval. Is there a command can be used in ioc shell?
Best regards,
Zhang Yuliang
- Re: setting NTP time sync interval on vxWorks Ralph Lange
Re: stream device - multiple values from a string Mark Rivers
<2015>
RE: stream device - multiple values from a string peter.owens
<2015>
