1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: epicsExit (); function exits the IOC but the Linux console requires a resest to be operative
Date: Tue, 30 Jun 2015 23:47:10 +0200
Thank you very much Andrew for the solutions!
Regards!
Diego
2015-06-30 20:55 GMT+02:00 Andrew Johnson <[email protected]>:
Hi again,
On 06/30/2015 01:25 PM, Andrew Johnson wrote:
> I can think of a few ways around the problem, at least one of which we
> ought to implement, but it would be simplest for you to start the IOC
> from a script which runs 'stty sane' immediately after the IOC exits.
> That command should be sufficient and is a little less severe than a
> full terminal reset.
Or you could apply this patch to base...
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
epicsExit (); function exits the IOC but the Linux console requires a resest to be operative Diego Sanz
Re: epicsExit (); function exits the IOC but the Linux console requires a resest to be operative Andrew Johnson
Prev: Re: epicsExit (); function exits the IOC but the Linux console requires a resest to be operative Andrew Johnson
Next: epicsScanDouble behavior change in R3.15 Priller, John
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: autosave ---Data coverage l123173
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
