Hi Li,
I think you want an archiver. You want not only the current value of a PV to be saved, but all values. You probably also want the times when the value changed. Yes? If so, autosave is not the tool you want. I haven't used or deployed an archiver, but others
on this list are expert at it. There are several solutions.
Tim Mooney ( [email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Hi everyone,
I have a little question about the autosave module. (RH 6.0, synApp5-6, autosave4-8)
I started the xxx module and autosave module worked well, but the newest data would be covered, I want all number of the data(pv) be saved.
I did not use the array, the data is just a numble.
Could you give me some advice?
Thank you,
Li xing
- autosave ---Data coverage l123173
Re: epicsExit (); function exits the IOC but the Linux console requires a resest to be operative Andrew Johnson
<2015>
epicsScanDouble behavior change in R3.15 Priller, John
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
