All the IOC shell commands are also C functions which can be called
directly.
Also, if you look in the *Main.cpp file generated by makeBaseApp, there
are two calls to iocsh(). The first with a non-NULL argument reads a
file. The second call with NULL starts the interactive shell.
https://github.com/epics-base/epics-base/blob/3.16/src/template/base/top/iocApp/src/_APPNAME_Main.cpp
There is also iocshCmd("") which takes a shell command as a string.
> just to be more clear, the application uses the stdin/stdout to control
> its states and I cannot use it for iocsh - how can I create an IOC
> "inside" my existing application ?
That said, you might want to explore alternatives. The IOC shell is a
handle debugging tool which I'd be reluctant to give up.
Michael
On 06/26/2015 10:29 AM, [email protected] wrote:
> Hi,
> I have developed for a Linux embedded board called uSOP various EPICS IOCs
> that publish different PVs for Belle2 environmental data (temperature,
> humidity);
> to do these tasks I use makeBaseApp.pl scripts to start developing and
> the result is an IOC that provide an iocsh prompt;
> now I have to add, for a new developing activity, some EPICS PVs to an
> exisiting application (not EPICS-enabled) and my question is how to do
> this in a simple and effective way...
> Thanks in advance,
> Gennaro
- IOC without iocsh [email protected]
RE: IOC without iocsh Mooney, Tim M.
Re: IOC without iocsh Andrew Johnson
<2015>
<2015>
