Hi Paul,
This is basically a software triggered analogue read. Often ai’s have hardware triggers to tell the ADC to sample – frequently across many channels as you propose.
The triggers have to be supported by the driver layer, of course. A software trigger (as you propose) would typically be represented by a binary output record, which would cause the driver to trigger sampling, and the values would be fed back to the Ai records
by having them I/O Intr scanned.
However, all this needs proper support in the driver. It is best to start off with a board with a driver that supports all this, but otherwise you need to write
a suitable driver for your board. In the VME world, we use the Hytec 8401 for this sort of job – the software manual is on the Hytec website:
http://www.hytec-electronics.co.uk/PDF/Hytec%20EPICS%20Device%20Driver%20User%20Manual.pdf.
There is also some areaDetector work going on to generate a 2-D dataset from multiple triggers across many channels – that may be interesting depending on your
use case.
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
On Behalf Of Stephen Paul
Sent: 23 June 2015 06:37
To: [email protected]
Subject: multi-channel analog i/p
Hi guys,
I have a 32-channel analog input board. I don't want to use 32 ai records reach reading directly from h/w.
Instead , I first want a record and its device support to read all the channels from the board in one go and then pass these values to individual 32 ai records for conversion.
Can anyone suggest what type of record I can use before ai record to achieve this ?
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
- multi-channel analog i/p Stephen Paul
multi-channel analog i/p bob dalesio
<2015>
Re: multi-channel analog i/p Hartman, Steven M.
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
