1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Is there a device simulator to test against an Asyn/StreamDevice IOC App
To: Mazanec Tomáš <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 12 Jun 2015 08:35:14 -0700
Thanks everyone,
I will try the simulators :)
Cheers,
Ernest
On 06/12/2015 01:40 AM, Mazanec Tomáš wrote:
Hi Ernest
I have a simple TCP server, written in python, which sends ascii string reply on request. As a part of our streamdevice IOC template, the server is hooked up with streamdevice-based IOC like:
drvAsynIPPortConfigure("$(SYSASYNPORT)","localhost:5000",0,0,0)
You can try the server e.g. with netcat utility:
nc localhost 5000
or include records from template and streamdev protocol file (all in the attached tarball).
Cheers,
Tomas
Od: [email protected] [[email protected]] za uživatele Williams Jr., Ernest L. [[email protected]]
Odesláno: 12. června 2015 5:25
Komu: [email protected]
Předmět: Is there a device simulator to test against an Asyn/StreamDevice IOC   App
Hi everyone,
I just followed this thread:
  "Testing UIs against real databases using simulation modeTesting UIs against real databases using simulation mode"
on EPICS Tech Talk.
I would like to test a streamdevice enabled IOC Application against a simulated device.
Has someone already built a Python-based Device simulator?
Cheers,
Ernest
Is there a device simulator to test against an Asyn/StreamDevice IOC App Williams Jr., Ernest L.
RE: Is there a device simulator to test against an Asyn/StreamDevice IOC App Mazanec Tomáš
Prev: RE: Is there a device simulator to test against an Asyn/StreamDevice IOC App Mazanec Tomáš
Next: Re: Is there a device simulator to test against an Asyn/StreamDevice IOC App jon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
