Hi Andrew,
I reopen a Thread about tricky behavior of dbloadtemplate which can not translates more 100 macros in one shot.
I have these errors when I start a softIOC
More than dbTemplateMaxVars = 100 macro variables used
Substitution file error.
line 17: 'VANODEMES__FUNCTION'
line 18: 'TDISMES__FUNCTION'
line 18: 'DEBEAUDISMES__OFFSET'
line 18: 'LOCKSTATE__OFFSET'
/admin/spiral2/scripts/bootIOC: line 80: 16751 Erreur de segmentation ./$IOC_CMD_SCRIPT
I have changed the value of dbTemplateMaxVars to 900 in base/src/dbtools/dbLoadTemplate.y but the value shown in error messages stills to 100.
I am sure I made something wrong, but in earlier EPICS version I remenber having changed the max values inside dbtools and just having type a "make" to see changes.
What must I do to push changes with this new version of dbtools?
Thanks for your help.
Dominique.
Subject: Re: Macros limited (edition ;-)
To: [email protected]
Cc: Touchard Dominique <[email protected]>
Date: Fri, 5 Jul 2013 10:39:43 -0500
Hi Dominique,
On 2013-07-05 Dominique Touchard wrote:
> It seems that the number of macros for template substitutions during IOC
> startup is limited to 100. Over, a segmentation fault stop the IOCs.
> Is this number correct? Is there any reason?
I was surprised but you're right, src/dbtools/dbLoadTemplate.y defines
VAR_MAX_VARS as 100 which sets a limit to the number of variables that
dbLoadTemplate() can handle. It also defines VAR_MAX_VAR_STRING as 5000
setting the maximum size of the "variable=value,..." string which it
constructs to pass to dbLoadRecords(). In neither case though does it check
when the storage limit set by those macros gets exceeded, thus causing a
crash. This is obviously unacceptable and needs to be fixed in Base.
To get around this limit for a particular application you could do the
template expansion on the host at build time using the msi (Macro
Substitution and Include) program which is distributed as an EPICS extension.
You can also increase the above values in your source code and rebuild base,
which might be a simpler fix in some circumstances.
I have filed a bug-report for this issue. If someone feels inclined to look
at rewriting the dbLoadTemplate() code to remove these limitations please let
me know.
https://bugs.launchpad.net/epics-base/+bug/1198234
- Andrew
- Re: Macros limited (edition ;-) Andrew Johnson
EPICS support for LinMot E1100-GP Marcin Lukaszewski
<2015>
<2015>
