Basler should be informed that this file, with a .xml extension, is not
"well-formed". The first line "Basler-21630837" certainly breaks the
XML API.
On 06/04/2015 08:35 AM, [email protected] wrote:
It does indeed expect this. Aravis also started printing the camera name at the top of the genicam file which is not very helpful, so you should remove the line:
Basler-21630837
and replace it with:
<?xml version="1.0" encoding="utf-8"?>
I should really fix the script to be robust to this...
Tom Cobb
-----Original Message-----
[email protected]] On Behalf Of Pete Jemian
Sent: 04 June 2015 14:30
To: [email protected]
Subject: Re: aravisGigE areaDetector with Basler camera
The minidom XML support in aravisGigEApp/src/makeDbAndEdl.py fails on
parsing the very first part of the XML file.
Can it be that the XML file does not start with a declaration line?
Does the support file expect this? Such as:
<?xml version="1.0" encoding="UTF-8"?>
On 06/04/2015 08:25 AM, Specht, Eliot D. wrote:
I'm trying to use aravisGigE to drive a Basler acA1920 ethernet camera
with areaDetector. I'm following the instructions at
https://github.com/areaDetector/aravisGigE to add a new camera. As
detailed below, I can get an XML file from the camera, but
makeDbAndEdl.py is not parsing this file. The XML file is large, but the
failure seems to be right at the beginning. Am I doing something stupid,
or is the Basler camera incompatible with aravisGigE?
FIRST TWO LINES OF XML FILE:
Basler-21630837
<RegisterDescription
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns="http://www.genicam.org/GenApi/Version_1_0"
xsi:schemaLocation="http://www.genicam.org/GenApi/Version_1_0
http://www.genicam.org/GenApi/GenApiSchema_Version_1_0.xsd"
MajorVersion="3" MinorVersion="7" ModelName="GigECamera"
ProductGuid="1F3C6A72-7842-4edd-9130-E2E90A2058BA"
SchemaMajorVersion="1" SchemaMinorVersion="0"
SchemaSubMinorVersion="1"
StandardNameSpace="GEV" SubMinorVersion="0" ToolTip="Basler generic
GigEVision camera interface" VendorName="Basler"
VersionGuid="6512A424-1B05-4C68-99D6-91F0E31857CD">
<Category Name="Root" NameSpace="Standard">
ATTEMPT TO ADD NEW CAMERA:
[root@video aravisGigE]#
Basler_acA1920.xmltoolbin/linux-x86_64/arv-tool-0.4m
Basler-21630837
[root@video aravisGigE]# bin/linux-x86_64/arv-tool-0.4 -n
"Basler-21630837" genicam > Basler_acA1920.xml
[root@video aravisGigE]# aravisGigEApp/src/makeDbAndEdl.py
Basler_acA1920.xml Basler_acA
Traceback (most recent call last):
File "aravisGigEApp/src/makeDbAndEdl.py", line 22, in <module>
xml_root = parse(args[0])
File "/usr/lib64/python2.7/xml/dom/minidom.py", line 1921, in parse
return expatbuilder.parse(file)
File "/usr/lib64/python2.7/xml/dom/expatbuilder.py", line 924, in parse
result = builder.parseFile(fp)
File "/usr/lib64/python2.7/xml/dom/expatbuilder.py", line 207, in
parseFile
parser.Parse(buffer, 0)
xml.parsers.expat.ExpatError: syntax error: line 1, column 0
Eliot Specht Voice: (865)574-7682
Oak Ridge National Laboratory FAX: (865)574-4913
P.O. Box 2008, MS 6064
Oak Ridge, TN 37831-6064
Pete R. Jemian, Ph.D. <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source, Argonne National Laboratory
Argonne, IL 60439 630 - 252 - 3189
Education is the one thing for which people
are willing to pay yet not receive.
- RE: aravisGigE areaDetector with Basler camera tom.cobb
- aravisGigE areaDetector with Basler camera Specht, Eliot D.
- Re: aravisGigE areaDetector with Basler camera Pete Jemian
RE: Draft requirements document for enhanced EPICS motor support Mooney, Tim M.
<2015>
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
