1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: aravisGigE areaDetector with Basler camera
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Thu, 4 Jun 2015 13:35:13 +0000
It does indeed expect this. Aravis also started printing the camera name at the top of the genicam file which is not very helpful, so you should remove the line:
Basler-21630837
and replace it with:
<?xml version="1.0" encoding="utf-8"?>
I should really fix the script to be robust to this...
Tom Cobb
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Pete Jemian
> Sent: 04 June 2015 14:30
> To: [email protected]
> Subject: Re: aravisGigE areaDetector with Basler camera
> The minidom XML support in aravisGigEApp/src/makeDbAndEdl.py fails on
> parsing the very first part of the XML file.
> Can it be that the XML file does not start with a declaration line?
> Does the support file expect this?  Such as:
> <?xml version="1.0" encoding="UTF-8"?>
> On 06/04/2015 08:25 AM, Specht, Eliot D. wrote:
> > I'm trying to use aravisGigE to drive a Basler acA1920 ethernet camera
> > with areaDetector. I'm following the instructions at
> > https://github.com/areaDetector/aravisGigE to add a new camera. As
> > detailed below, I can get an XML file from the camera, but
> > makeDbAndEdl.py is not parsing this file. The XML file is large, but the
> > failure seems to be right at the beginning. Am I doing something stupid,
> > or is the Basler camera incompatible with aravisGigE?
> > FIRST TWO LINES OF XML FILE:
> > Basler-21630837
> > <RegisterDescription
> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance";
> > xmlns="http://www.genicam.org/GenApi/Version_1_0";
> > xsi:schemaLocation="http://www.genicam.org/GenApi/Version_1_0
> > http://www.genicam.org/GenApi/GenApiSchema_Version_1_0.xsd";
> > MajorVersion="3" MinorVersion="7" ModelName="GigECamera"
> > ProductGuid="1F3C6A72-7842-4edd-9130-E2E90A2058BA"
> > SchemaMajorVersion="1" SchemaMinorVersion="0"
> SchemaSubMinorVersion="1"
> > StandardNameSpace="GEV" SubMinorVersion="0" ToolTip="Basler generic
> > GigEVision camera interface" VendorName="Basler"
> > VersionGuid="6512A424-1B05-4C68-99D6-91F0E31857CD">
> >    <Category Name="Root" NameSpace="Standard">
> > ATTEMPT TO ADD NEW CAMERA:
> > [root@video aravisGigE]#
> > Basler_acA1920.xmltoolbin/linux-x86_64/arv-tool-0.4m
> > Basler-21630837
> > [root@video aravisGigE]# bin/linux-x86_64/arv-tool-0.4 -n
> > "Basler-21630837" genicam > Basler_acA1920.xml
> > [root@video aravisGigE]# aravisGigEApp/src/makeDbAndEdl.py
> > Basler_acA1920.xml Basler_acA
> > Traceback (most recent call last):
> >    File "aravisGigEApp/src/makeDbAndEdl.py", line 22, in <module>
> >      xml_root = parse(args[0])
> >    File "/usr/lib64/python2.7/xml/dom/minidom.py", line 1921, in parse
> >      return expatbuilder.parse(file)
> >    File "/usr/lib64/python2.7/xml/dom/expatbuilder.py", line 924, in parse
> >      result = builder.parseFile(fp)
> >    File "/usr/lib64/python2.7/xml/dom/expatbuilder.py", line 207, in
> > parseFile
> >      parser.Parse(buffer, 0)
> > xml.parsers.expat.ExpatError: syntax error: line 1, column 0
> > Eliot Specht                        Voice: (865)574-7682
> > Oak Ridge National Laboratory       FAX:   (865)574-4913
> > P.O. Box 2008, MS 6064
> > Oak Ridge, TN 37831-6064
>   Pete R. Jemian, Ph.D.                <[email protected]>
>   Beam line Controls and Data Acquisition, Group Leader
>   Advanced Photon Source,   Argonne National Laboratory
>   Argonne, IL  60439                   630 - 252 - 3189
>      Education is the one thing for which people
>         are willing to pay yet not receive.
Re: aravisGigE areaDetector with Basler camera Pete Jemian
aravisGigE areaDetector with Basler camera Specht, Eliot D.
Prev: Re: aravisGigE areaDetector with Basler camera Pete Jemian
Next: RE: Draft requirements document for enhanced EPICS motor support Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: aravisGigE areaDetector with Basler camera Pete Jemian
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
