Hello tech-talkers, When compiling a stream based app that uses deviocstat support, I encounter the following error: No rule to make target `../../../lib/windows-x64/devIocStats.lib' base (3.14.12.4) is compiled as dynamic for the windows-x64 arch. When compiling the same app under linux-x64 everything works fine. I am assuming the issue is that I did not compile epics and synapps support statically in the windows OS. If that is the issue then how do I use deviocstats successfully for dynamic builds. I am using devIocStats-3-1-7 currently. Any help/suggestions is much appreciated. -- Alireza Panna University of Maryland, College Park
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
