1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: in 3.15.2 the file aSubRecord.h is not properly generated by dbdToRecordtypeH.pl
To: [email protected]
Date: Wed, 03 Jun 2015 15:36:54 +0200
I found the following problem when compiling the gensub record module with EPICS base 3.15.2, but it also exists for the aSub record: the record field "NOT" is generated as "epicsUInt32 NOT" instead of "epicsUInt32 not".
typedef struct aSubRecord {
    epicsUInt32         nos;        /* Max. elements in S */
    epicsUInt32         NOT;        /* Max. elements in T */
    epicsUInt32         nou;        /* Max. elements in U */
} aSubRecord;
Yves
Re: in 3.15.2 the file aSubRecord.h is not properly generated by dbdToRecordtypeH.pl Andrew Johnson
Prev: RE: Problems with asyn read calls at driver exit Sergio Esquembri
Next: in 3.15.2 aSubRecord.h is not properly generated by dbdToRecordtypeH.pl Lussignol Yves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Rotating or deleting procServ log files Jani Hakala
Next: Re: in 3.15.2 the file aSubRecord.h is not properly generated by dbdToRecordtypeH.pl Andrew Johnson
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
