1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Rotating or deleting procServ log files
Date: Tue, 2 Jun 2015 20:39:12 +0000
On Jun 2, 2015, at 4:22 PM, Mark Rivers <[email protected]> wrote:
> procServ log files sometimes get very large, so we would like to rotate them, and or delete them and start a new one without restarting the procServ process.
> Is this possible?  I found that if I rename the log file procServ just kept writing to the renamed file.  If I delete the log file procServ does not create a new one, it just silently continues without logging anything.
Hi Mark--
Since procServ has the file open, moving it won't help (procServ will continue to write to the same file handle). Likewise, trying to delete the file won't actually free up the space on disk until procServ closes the file (procServ will continue writing to the same inode which you just don't see anymore in a directory listing).
On Linux, we use logrotate to keep our procServ logs to a reasonable size. The logrotate option 'copytruncate' will do what you want (save a copy and then truncate the file being written to). If you don't have logrotate available, you can cat /dev/null on to the file to truncate it.
Steven Hartman
[email protected]
Rotating or deleting procServ log files Mark Rivers
Prev: Rotating or deleting procServ log files Mark Rivers
Next: Re: Rotating or deleting procServ log files Wesley Moore
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
