I'm relatively new to epics and writing protocols, so please forgive me if I muddle up my terminology. I'm trying to communicate with a CAEN VME8100 over a network. I would like to be able to read out the various channels and write them into epics to be displayed in an edl panel. I have most of this done, however, I am only reading out integer values. So for example, rather than reading the voltage as 5.23 V I am readding 5 V. It appears that this is not a rounding error, instead I am only reading the first digit of the output. My protocol calling in the voltage looks something like: readVMON0 { out "$CMD:MON,CH:0,PAR:VMON"; in "#CMD:OK,VAL:%(PV_NAME.RVAL)f"; } I have a header to the protocol file: interminator = "\r\n"; outterminator = "\n"; replytimout = 2000; separator = ""; Finally I have the PV in the IOC database as: record(ai, "PV_NAME") { field(DTYP,"stream") field(SCAN,"10 second") field(PREC,"2") field(INP,"@CAEN.protocol readVMON0 VMEport 0") } where VMEport is defined in st.cmd and holds the network address of the device. I have no idea what the trailing zero is... it came that way. Testing this earlier I put a space between the PV name and type so that the "in" line in the protocol file looked like: in "#CMD:OK,VAL:%(PV_NAME.RVAL) f"; and got an error: PV_NAME: Input "11.98" does not match format % f so at some point I must be reading in the whole thing.. Thanks for taking a look -Chris
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
