1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: devlib2 and asyn Pros/Cons
From: "Williams Jr., Ernest L." <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Date: Thu, 21 May 2015 23:05:42 +0000
Sent: Thursday, May 21, 2015 11:45 AM
To: Williams Jr., Ernest L.
Cc: Rivers, Mark L.; [email protected]
Subject: Re: devlib2 and  asyn  Pros/Cons
Hi Earnest,
There is an epicsEndian.h header in 3.14 that tells you what your CPUs endianness is, and the MMIO features of devlib2 that have now been included in Base-3.15 do the necessary byte-swapping. If that doesn't answer your question then we probably don't understand what you're asking.
Excellent. :)
Indeed, 3.15 has the goodies.
Cheers,
Ernest
- Andrew
Sent from my iPad
> On May 21, 2015, at 2:34 PM, Williams Jr., Ernest L. <[email protected]> wrote:
> Sent from my iPhone
>> On May 21, 2015, at 10:32 AM, Mark Rivers <[email protected]> wrote:
>> Hi Ernest,
>> I don't think it is really and either/or question with devlib2 and asyn.  At least for the drivers I've seen they work together.  For example I've written an asyn driver for the SIS3820, but it would be nice to have devlib2 functions to do OS-independent DMA with it.  So asyn drivers make calls to devlib2 functions for OS-independent access to the VME or PCI bus.
> What about endianness ?
> That would be also nice
>> How does devlib2 get involved with Ethernet/RS-232 based devices?
> Not all, as far as I know
> But I think Michael Davidsaver or Till will chime in here :-)
> Cheers
> Ernest
>> Mark
>> From: [email protected] [[email protected]] on behalf of Williams Jr., Ernest L. [[email protected]]
>> Sent: Thursday, May 21, 2015 9:26 AM
>> To: [email protected]
>> Subject: devlib2 and  asyn  Pros/Cons
>> Hi everyone,
>> We would like to go down a path of standardizing new EPICS drivers that we develop here at SLAC.
>> Can folks speak about pros/cons for using devlib2-based approach  versus an asyn-based approach for access
>> to (1) PCI bus access, VME64x CSR/CSR, and other memory-mapped devices; (2) ethernet/RS232 based; stream-based ?
>> Here at SLAC we have a module that Till wrote which addresses:
>> (1) memory and I/O barriers, (2) endianess
>> Is this something that belongs in or is now in EPICS BASE?
>> Cheers,
>> Ernest
devlib2 and asyn Pros/Cons Williams Jr., Ernest L.
RE: devlib2 and asyn Pros/Cons Mark Rivers
Re: devlib2 and asyn Pros/Cons Williams Jr., Ernest L.
Re: devlib2 and asyn Pros/Cons Johnson, Andrew N.
Prev: Re: Problems building EPICS-CPP-4.4.0 mrkraimer
Next: Re: Problems building EPICS-CPP-4.4.0 Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: devlib2 and asyn Pros/Cons Johnson, Andrew N.
Next: Problems building EPICS-CPP-4.4.0 Mark Rivers
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
