1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Problems building EPICS-CPP-4.4.0
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 21 May 2015 19:15:58 +0000
Folks,
I ran into some minor problems building the latest release of EPICS V4.
make clean has an error:
make[1]: Entering directory `/usr/local/epics/EPICS-CPP-4.4.0/pvaPy'
Makefile:13: *** mixed implicit and normal rules.  Stop.
make[1]: Leaving directory `/usr/local/epics/EPICS-CPP-4.4.0/pvaPy'
make: *** [clean] Error 2
Parallel make did not work:
corvette:local/epics/EPICS-CPP-4.4.0>make -sj
make[3]: *** No rule to make target `../../lib/linux-x86/libpvAccess.a', needed by `HelloService'.  Stop.
make[3]: *** Waiting for unfinished jobs....
../HelloServiceMain.cpp:8:26: fatal error: pv/rpcServer.h: No such file or directory../HelloService.cpp:8:26: fatal error: pv/rpcServer.h: No such file or directory
compilation terminated.
make[3]: *** [HelloService.o] Error 1
make[3]: *** [HelloServiceMain.o] Error 1
make[2]: *** [install.linux-x86] Error 2
make[1]: *** [helloWorldApp.install] Error 2
make: *** [helloWorld] Error 2
make: *** Waiting for unfinished jobs....
make[3]: *** No rule to make target `../../lib/linux-x86/libpvAccess.a', needed by `libpvaSrv.a'.  Stop.
make[3]: *** No rule to make target `../../lib/linux-x86/libpvAccess.a', needed by `libpvDatabase.a'.  Stop.
Prev: Re: devlib2 and asyn Pros/Cons Johnson, Andrew N.
Next: Re: Problems building EPICS-CPP-4.4.0 mrkraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: devlib2 and asyn Pros/Cons Williams Jr., Ernest L.
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
