1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS web GUIs using websockets
To: [email protected]
Cc: [email protected], [email protected]
Date: Wed, 20 May 2015 21:40:34 +0000
Has anyone used WebPDA (http://webpda.org/)?  Comments on it?
On Wed, May 20, 2015 at 09:36:29AM +0000, [email protected] wrote:
> Hi Emmanuel,
> One requirement is that the client should only need an up to date browser, so a
> python or C++ client is not an option.
> I found a couple of options for running QML in the browser, both of which seem
> to be prototypes:
> http://silk.qtquick.me/
> https://github.com/Plaristote/qmlweb
> Have you used either of them?
> Thanks,
> Tom Cobb
> +44 (0)1235 778582
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Emmanuel Mayssat
> Sent: 19 May 2015 23:25
> To: Cobb, Tom (DLSLtd,RAL,TEC); EPICS mailing list
> Subject: RE: EPICS web GUIs using websockets
> Tom,
> http://doc.qt.io/qt-5/qtwebsockets-examples.html
> http://doc.qt.io/qt-5/qtwebsockets-echoserver-example.html
> As you will find out, websocket interfaces are not limited to client's web
> browser only (i.e HTML only).
> All the Qt based cloud services are using websockets. As a result, great care
> has been taken to easily implement websockets with Qt.
> http://www.slideshare.net/emayssat/
> qtdd14-give-a-push-to-your-qt-application-with-websockets
> If you want a python client, have a look at pyqt5 and
> http://stackoverflow.com/questions/15092076/
> pyqt-and-websocket-client-listen-websocket-in-background
> If you understand how Qt works (start a dummy QML project in Qt Creator, and
> you understand signals and slots), you will realize that QML is the easiest way
> to write your client (with qt)
> http://www.qmlbook.com
> http://doc.qt.io/qt-5/qt-websockets-qmlmodule.html
> I hope this helps,
> Emmanuel Mayssat
> http://www.epicsqt.org
> > Subject: EPICS web GUIs using websockets
> > Date: Tue, 19 May 2015 10:03:42 +0000
> > Hi all,
> > I'm looking to create a web interface for a device running embedded Linux
> including an on-board IOC. I would like to run a small python based webserver
> on the device which communicated to the IOC and exposed a web-socket connection
> to allow the GUI running in the client's browser to set and get PVs.
> > A while back there was a thread on browser based EPICS GUIs:
> > http://www.aps.anl.gov/epics/tech-talk/2014/msg01824.php
> > There were a few responses that used CA on the server and web-sockets to
> communicate the data to the client:
> > * http://webpda.org/ (last commit 2013)
> > * http://epaper.kek.jp/ICALEPCS2013/papers/tuppc110.pdf (can't find the code)
> > * https://github.com/AustralianSynchrotron/web-epics (last commit March 2014)
> > * https://github.com/diirt/diirt/tree/master/pods/web-pods (last commit April
> 2015)
> > I found that webpods was the most developed, and the only one with a decent
> specification:
> > * https://github.com/diirt/diirt/wiki/WebPods-Protocol-Specification-v1
> > But it was written in java, so I started writing a small Python server so I
> could reuse the javascript library:
> > * https://github.com/dls-controls/PyPODS
> > I've now reached the proof of principle stage, and as far as I can tell,
> no-one has got beyond that point on any of these projects! Has anyone actually
> deployed a project like this? Is anyone actively working on something like
> this?
> > Thanks,
> > Tom Cobb
> > This e-mail and any attachments may contain confidential, copyright and or
> privileged material, and are for the use of the intended addressee only. If you
> are not the intended addressee or an authorised recipient of the addressee
> please notify us of receipt by returning the e-mail and do not use, copy,
> retain, distribute or disclose the information in or attached to the e-mail.
> > Any opinions expressed within this e-mail are those of the individual and not
> necessarily of Diamond Light Source Ltd.
> > Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> attachments are free from viruses and we cannot accept liability for any damage
> which you may sustain as a result of software viruses which may be transmitted
> in or with the message.
> > Diamond Light Source Limited (company no. 4375679). Registered in England and
> Wales with its registered office at Diamond House, Harwell Science and
> Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments
> are free from viruses and we cannot accept liability for any damage which you
> may sustain as a result of software viruses which may be transmitted in or with
> the message.
Re: EPICS web GUIs using websockets Jani Hakala
EPICS web GUIs using websockets tom.cobb
RE: EPICS web GUIs using websockets Emmanuel Mayssat
RE: EPICS web GUIs using websockets tom.cobb
Prev: EPICS Motor Working Group Pete Jemian
Next: RE: about Galil controller in linux-64bit system LiuP
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EPICS web GUIs using websockets tom.cobb
Next: Re: EPICS web GUIs using websockets Jani Hakala
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
