1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Channel Access questions
Date: Wed, 20 May 2015 15:48:18 +0000
Hello,
I have two questions about channel Access.
First Question:
Our configurations has a client workstation with two Ethernet ports – 192.168.1.235 and 192.168.2.235. A server with two Ethernet ports 192.168.1.70 and 192.168.2.70.
I want channel access to totally ignore the 192.168.1.X subnet.
I thought all I would have to do is set EPICS_CA_ADDR_LIST=”192.168.2.70” and EPICS_CA_AUTO_ADDR_LIST=”NO” on the client side. And EPICS_CAS_AUTO_BEACON_ADDR_LIST=”NO”  and EPICS_CAS_BEACON_ADDR_LIST=”192.168.2.255” on the server side. Those did not work as well as some other variations I tried.
However using wireshark all the search request from the client are using the 192.168.1.x subnet?
What am I doing wrong?
Second Question:
Using wireshark after my client connects I see a lot of TCP responses from the server to the client of CA_PROTO_EVENT_ADD. I don’t understand these, can someone explain?
Thanks
Re: Channel Access questions Michael Davidsaver
Prev: Re: EPICS device driver support for Tektronix AFG3000C Bruno Martins
Next: Re: Channel Access questions Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: IOC monitoring Andrew Johnson
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
