Hi Isabella,
Thanks for studying this. I forgot that the scalcout record did not honor the PREC field for conversions to string until release R3-4-1.
Tim Mooney ( [email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Sent: Monday, May 18, 2015 6:38 AM
To: Mooney, Tim M.
Cc: [email protected]
Subject: Re: scalcout fails to write to bo - (partially?) solved
Hi Tim,
Thank you for your reply.
Option 2 is the (only) one that does the trick. I had tried before, with the variant of '1' and '0' being in the DD and EE fields, and it didn't work, but now it did, so maybe I had something not set correctly there...
Option 1 DOES write to the bo correctly, but it breaks the "When Zero" OOPT (as there is no zero output anymore), which I need. So it works in general, but in my case I need to have 1 or 0.
Option 3 doesn't work: I had tried it before, and I re-tested again now, but I get the Illegal choice message.
So overall I have a solution to go ahead with, but it works only when the CALC outputs a string and then converts it to int, I can't seem to use an int directly and push it into the bo, without going through the string.
Thanks for your help!
Isabella
- Re: scalcout fails to write to bo - (partially?) solved Isabella Rey
Re: Fortran CA Client Interface Matt Newville
<2015>
Bug in camserver for Pilatus detectors with large file systems Mark Rivers
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
