1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Expected database load times
To: Klemen Vodopivec <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 16 May 2015 11:16:31 +0000
Hmmmm, 100,000 records in 30 seconds. That sounds pretty good.
What in the world are you doing with an IOC with 100K records?
What is the idle time once it is running?
More files = slower, we have always seen that.
Are you loading only fields which are not the default values?
Have you profiled the code?
Did you try converting it to binary on the workstation ahead of time?
Please share your results when you are done.
Bob
From: [email protected] [[email protected]] on behalf of Klemen Vodopivec [[email protected]]
Sent: Friday, May 15, 2015 1:11 PM
To: [email protected]
Subject: Expected database load times
Dear all,
I'm interested in the time it takes to load database(s) with thousands of records. For about 100,000 records we're seeing IOC boot times in range 30s or more when loaded with dbLoadRecords(). Without related database the IOC boots instantly. Most records connect to asyn port. Disabling macro substitution doesn't seem to have much effect. When spread into several files with about the same amount of records one can observe gradually slowing down the time it takes to load one file.
What are others' experiencing? Is there anything to speed it up?
Not a big concern, though, since our IOCs are mostly running all times.
Thanks, Klemen
Expected database load times Klemen Vodopivec
Prev: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
Next: Fortran CA Client Interface chengmaosong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Expected database load times Andrew Johnson
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
