1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy
To: "Wang Xiaoqiang \(PSI\)" <[email protected]>, Michael Davidsaver <[email protected]>
Cc: Epics <[email protected]>
Date: Fri, 15 May 2015 12:27:19 -0700
On Fri, May 15 2015, "Wang Xiaoqiang (PSI)" <[email protected]> wrote:
> Thanks for the hints. In pcaspy library, the PV instances are created on startup and live until application quits.
> The casPV::destroy method is not implemented.
> https://github.com/paulscherrerinstitute/pcaspy/blob/master/pcaspy/pv.cpp#L112
How is the garbage collection handled?  Since the problem does seem to
occur when subscriptions are disconnected, presumably something is
destroyed at that point.
> But it does implement casPV::createChannel for access security group.
> Will that cause this double free problem?
FWIW we're not using any access control in our application.
jamie.
Attachment: signature.asc
Description: PGP signature
Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
"epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Wang Xiaoqiang (PSI)
Prev: Re: Expected database load times Andrew Johnson
Next: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Wang Xiaoqiang (PSI)
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
