1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Question about device support
To: EPICS Tech Talk <[email protected]>
Date: Fri, 15 May 2015 08:51:42 +0200
Hey all,
I'm currently working together with the company iseg Spezialelektronik GmbH
to develop EPICS device support for their high voltage power supplies.
Two questions came up so far:
1) It is possible that some Control values change their values,
    e.g. if a trip occures the "channel is on" control word is set to off.
    Can the device support in such a case change the value of a bo record?
    Will the record be processed when changing its value from device
support?
    (I was thinking of some kind of callback here)
2) The device support will not directly communicate with the hardware,
    but with a daemon in between (iseg also wants to support OPC server
and others,
    so one common interface for all).
    This daemon gives me the value and timestamp of its last change.
    Is it possible to give this timestamp through the device support to
the record?
    From the record reference manual I guess not...
    What would be your suggestion to make the timestamp
available/visible to the operator/experts?
Best regards,
Florian
| Dr. Florian Feldbauer                |
| Helmholtz-Institut Mainz /           |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36         |
| D-55128 Mainz                        |
| Office: SB1 / 00-213                 |
| Phone:  (+49)6131 / 39-29605         |
Re: Question about device support Ralph Lange
RE: Question about device support Mark Rivers
Prev: Re: AreaDetector Interface for Dectris EIGER? Bruno Martins
Next: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Wang Xiaoqiang (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Question about device support Ralph Lange
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
