One suggestion would be to try the latest base 3.14 release, 3.14.12.5. The 3.14.12.2 version you are running is 3.5 years old, and there have been a number of bug fixes.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Jameson Graef Rollins
Sent: Wednesday, May 13, 2015 4:04 PM
To: Michael Davidsaver; [email protected]
Subject: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy
On Wed, May 13 2015, Michael Davidsaver <[email protected]> wrote:
> The thread in question (it's sitting in cantProceed()). It is indeed in
> a PCAS call (see below).
Yes, I see now. Thanks so much for helping me track this down, Michael!
> One odd thing I notice. It seems that GDB finds the debug symbols for
> libCom, but not for libcas. It seems unlikely that this would be true
> if both libraries were from the same build. Also I note that libca is
> being loaded from a slightly different path (symlink?).
>> Reading symbols from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libCom.so.3.14...done.
>> Reading symbols from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libcas.so.3.14...(no debugging symbols found)...done.
>> Reading symbols from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14
I think this is just a symlink issue. We have:
base -> base-3.14.12.2/
> This might just be a quirk of GDB searching though. Can you check on a
> running process ("cat /proc/<pid>/maps") to see which libraries were loaded?
I include the full list of loaded EPICS library below [0].
> Also, running "ldd -v _pcas.so" might be interesting.
I'm unable to find a .so with this name, and in fact I don't see any
object files with the string 'pcas' in the name. I do however see a
"_cas.so" that's included with the pcaspy package [1].
>> Thread 1 (Thread 0x7f8658d49700 (LWP 26265)):
>> #0 0x00007f8658933d84 in pthread_cond_wait@@GLIBC_2.3.2 () from /lib/x86_64-linux-gnu/libpthread.so.0
>> #1 0x00007f86529ed809 in condWait (mutexId=0x301f080, condId=0x301f0a8) at ../../../src/libCom/osi/os/posix/osdEvent.c:75
>> #2 epicsEventWait (pevent=0x301f080) at ../../../src/libCom/osi/os/posix/osdEvent.c:137
>> #3 0x00007f86529ec158 in epicsThreadSuspendSelf () at ../../../src/libCom/osi/os/posix/osdThread.c:557
>> #4 0x00007f86529e2d05 in cantProceed (msg=<optimized out>) at ../../../src/libCom/misc/cantProceed.c:69
>> #5 0x00007f8652568525 in casPVI::getExtServer() const () from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libcas.so.3.14
>> #6 0x00007f8652c2efa3 in PV::postEvent (this=0x30a0200, value=...) at pcaspy/pv.cpp:83
>> #7 0x00007f8652c1fdc9 in _wrap_PV_postEvent (args=<optimized out>) at pcaspy/casdef_wrap.cpp:9193
>> #8 0x0000000000571b58 in PyEval_EvalFrameEx ()
Ok! So what's to be done here? Is this a problem in the pcaspy SWIG
bindings, or in libcas? I can't see anything obvious that is being
called incorrectly:
https://bazaar.launchpad.net/~epics-core/epics-base/3.14/view/head:/src/cas/generic/casPVI.cc#L320
jamie.
[0] $ sudo cat /proc/2497/maps | grep epics
7ff3f0611000-7ff3f062c000 r-xp 00000000 00:14 83495166 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbStaticIoc.so.3.14
7ff3f062c000-7ff3f082b000 ---p 0001b000 00:14 83495166 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbStaticIoc.so.3.14
7ff3f082b000-7ff3f082c000 r--p 0001a000 00:14 83495166 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbStaticIoc.so.3.14
7ff3f082c000-7ff3f082d000 rw-p 0001b000 00:14 83495166 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbStaticIoc.so.3.14
7ff3f082f000-7ff3f086b000 r-xp 00000000 00:14 83495480 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbIoc.so.3.14
7ff3f086b000-7ff3f0a6a000 ---p 0003c000 00:14 83495480 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbIoc.so.3.14
7ff3f0a6a000-7ff3f0a6c000 r--p 0003b000 00:14 83495480 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbIoc.so.3.14
7ff3f0a6c000-7ff3f0a6e000 rw-p 0003d000 00:14 83495480 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbIoc.so.3.14
7ff3f0a70000-7ff3f0ad0000 r-xp 00000000 00:14 83494965 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14
7ff3f0ad0000-7ff3f0ccf000 ---p 00060000 00:14 83494965 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14
7ff3f0ccf000-7ff3f0cd3000 r--p 0005f000 00:14 83494965 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14
7ff3f0cd3000-7ff3f0cd5000 rw-p 00063000 00:14 83494965 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14
7ff3f141f000-7ff3f142c000 r-xp 00000000 00:14 83495846 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libasIoc.so.3.14
7ff3f142c000-7ff3f162b000 ---p 0000d000 00:14 83495846 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libasIoc.so.3.14
7ff3f162b000-7ff3f162c000 r--p 0000c000 00:14 83495846 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libasIoc.so.3.14
7ff3f162c000-7ff3f162d000 rw-p 0000d000 00:14 83495846 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libasIoc.so.3.14
7ff3f162e000-7ff3f166e000 r-xp 00000000 00:14 83498603 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libcas.so.3.14
7ff3f166e000-7ff3f186e000 ---p 00040000 00:14 83498603 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libcas.so.3.14
7ff3f186e000-7ff3f1871000 r--p 00040000 00:14 83498603 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libcas.so.3.14
7ff3f1871000-7ff3f1872000 rw-p 00043000 00:14 83498603 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libcas.so.3.14
7ff3f1872000-7ff3f189f000 r-xp 00000000 00:14 83496980 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libgdd.so.3.14
7ff3f189f000-7ff3f1a9f000 ---p 0002d000 00:14 83496980 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libgdd.so.3.14
7ff3f1a9f000-7ff3f1aa0000 r--p 0002d000 00:14 83496980 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libgdd.so.3.14
7ff3f1aa0000-7ff3f1aa1000 rw-p 0002e000 00:14 83496980 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libgdd.so.3.14
7ff3f1aa1000-7ff3f1af4000 r-xp 00000000 00:14 83494540 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libCom.so.3.14
7ff3f1af4000-7ff3f1cf4000 ---p 00053000 00:14 83494540 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libCom.so.3.14
7ff3f1cf4000-7ff3f1cf7000 r--p 00053000 00:14 83494540 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libCom.so.3.14
7ff3f1cf7000-7ff3f1cf9000 rw-p 00056000 00:14 83494540 /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libCom.so.3.14
7ff3f1cfa000-7ff3f1d2a000 r-xp 00000000 00:14 83760456 /ligo/apps/ubuntu12/epics-3.14.12.2_long/pyext/pcaspy-0.4.1/lib/python2.7/site-packages/pcaspy/_cas.so
7ff3f1d2a000-7ff3f1f2a000 ---p 00030000 00:14 83760456 /ligo/apps/ubuntu12/epics-3.14.12.2_long/pyext/pcaspy-0.4.1/lib/python2.7/site-packages/pcaspy/_cas.so
7ff3f1f2a000-7ff3f1f2b000 r--p 00030000 00:14 83760456 /ligo/apps/ubuntu12/epics-3.14.12.2_long/pyext/pcaspy-0.4.1/lib/python2.7/site-packages/pcaspy/_cas.so
7ff3f1f2b000-7ff3f1f2e000 rw-p 00031000 00:14 83760456 /ligo/apps/ubuntu12/epics-3.14.12.2_long/pyext/pcaspy-0.4.1/lib/python2.7/site-packages/pcaspy/_cas.so
[1] $ ldd -v /ligo/apps/ubuntu12/epics/pyext/pcaspy-0.4.1/lib/python2.7/site-packages/pcaspy/_cas.so
linux-vdso.so.1 => (0x00007ffd619da000)
libCom.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libCom.so.3.14 (0x00007f3209706000)
libgdd.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libgdd.so.3.14 (0x00007f32094d7000)
libcas.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libcas.so.3.14 (0x00007f3209292000)
libasIoc.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libasIoc.so.3.14 (0x00007f3209083000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f3208d6c000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f3208b55000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f3208938000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f320857a000)
libreadline.so.6 => /lib/x86_64-linux-gnu/libreadline.so.6 (0x00007f3208337000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f320812f000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f3207f2b000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f3207c2e000)
libca.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14 (0x00007f32079c9000)
libdbIoc.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbIoc.so.3.14 (0x00007f3207787000)
libdbStaticIoc.so.3.14 => /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbStaticIoc.so.3.14 (0x00007f3207569000)
/lib64/ld-linux-x86-64.so.2 (0x00007f3209b95000)
libtinfo.so.5 => /lib/x86_64-linux-gnu/libtinfo.so.5 (0x00007f3207341000)
Version information:
/ligo/apps/ubuntu12/epics/pyext/pcaspy-0.4.1/lib/python2.7/site-packages/pcaspy/_cas.so:
libgcc_s.so.1 (GCC_3.0) => /lib/x86_64-linux-gnu/libgcc_s.so.1
libpthread.so.0 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libpthread.so.0
libc.so.6 (GLIBC_2.14) => /lib/x86_64-linux-gnu/libc.so.6
libc.so.6 (GLIBC_2.4) => /lib/x86_64-linux-gnu/libc.so.6
libc.so.6 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libc.so.6
libc.so.6 (GLIBC_2.3.4) => /lib/x86_64-linux-gnu/libc.so.6
libstdc++.so.6 (CXXABI_1.3) => /usr/lib/x86_64-linux-gnu/libstdc++.so.6
libstdc++.so.6 (GLIBCXX_3.4) => /usr/lib/x86_64-linux-gnu/libstdc++.so.6
/ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libCom.so.3.14:
librt.so.1 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/librt.so.1
libdl.so.2 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libdl.so.2
libpthread.so.0 (GLIBC_2.3.2) => /lib/x86_64-linux-gnu/libpthread.so.0
libc.so.6 (GLIBC_2.15) => /lib/x86_64-linux-gnu/libc.so.6
libc.so.6 (GLIBC_2.3) => /lib/x86_64-linux-gnu/libc.so.6
libm.so.6 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libm.so.6
/ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libgdd.so.3.14:
/ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libcas.so.3.14:
/ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libasIoc.so.3.14:
/usr/lib/x86_64-linux-gnu/libstdc++.so.6:
ld-linux-x86-64.so.2 (GLIBC_2.3) => /lib64/ld-linux-x86-64.so.2
libgcc_s.so.1 (GCC_4.2.0) => /lib/x86_64-linux-gnu/libgcc_s.so.1
libgcc_s.so.1 (GCC_3.3) => /lib/x86_64-linux-gnu/libgcc_s.so.1
libc.so.6 (GLIBC_2.3.2) => /lib/x86_64-linux-gnu/libc.so.6
/lib/x86_64-linux-gnu/libgcc_s.so.1:
/lib/x86_64-linux-gnu/libpthread.so.0:
ld-linux-x86-64.so.2 (GLIBC_2.2.5) => /lib64/ld-linux-x86-64.so.2
ld-linux-x86-64.so.2 (GLIBC_PRIVATE) => /lib64/ld-linux-x86-64.so.2
libc.so.6 (GLIBC_PRIVATE) => /lib/x86_64-linux-gnu/libc.so.6
/lib/x86_64-linux-gnu/libc.so.6:
/lib/x86_64-linux-gnu/libreadline.so.6:
libc.so.6 (GLIBC_2.11) => /lib/x86_64-linux-gnu/libc.so.6
/lib/x86_64-linux-gnu/librt.so.1:
libpthread.so.0 (GLIBC_PRIVATE) => /lib/x86_64-linux-gnu/libpthread.so.0
/lib/x86_64-linux-gnu/libdl.so.2:
/lib/x86_64-linux-gnu/libm.so.6:
/ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14:
/ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbIoc.so.3.14:
/ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libdbStaticIoc.so.3.14:
/lib/x86_64-linux-gnu/libtinfo.so.5:
- Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
- "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
- Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
<2015>
<2015>
