1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy
To: Mark Rivers <[email protected]>, Jameson Graef Rollins <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 13 May 2015 16:34:41 -0400
On 05/13/2015 03:55 PM, Mark Rivers wrote:
>> One odd thing I notice.  It seems that GDB finds the debug symbols for
>> libCom, but not for libcas.  It seems unlikely that this would be true
>> if both libraries were from the same build.
> I believe there was a problem in base that was causing debug symbols to be loaded for C code but not C++ code.  It was fixed in 3.14.12.4.
I guess you mean
http://www.aps.anl.gov/epics/tech-talk/2013/msg01659.php
Which effects OPT builds, as in this case.  So one of two is probably
explained.  libcas contains only C++ code.
"epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
RE: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Mark Rivers
Prev: RE: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Mark Rivers
Next: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
