1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy
To: Jameson Graef Rollins <[email protected]>, [email protected]
Date: Wed, 13 May 2015 15:25:43 -0400
On 05/13/2015 02:52 PM, Jameson Graef Rollins wrote:
> This program utilizes two processes: a "main" daemon process and a
> "worker" sub-process.  The daemon holds the PCAS, while the worker uses
> pyepics to do the work.
> Attached is the gdb bt output for the threads of both the "MAIN" and the
> "WORKER" for one of these wedged nodes.  Like I said, I'm pretty sure
> the problem is in the PCAS, so I think the problem is in the MAIN, but I
> include the WORKER bt for completeness.
> I don't actually have a wedged node right now, so I can't get any more
> info until it happens again.  If there's some other gdb info I can
> retrieve next time this happens, please do let me know.
The thread in question (it's sitting in cantProceed()).  It is indeed in
a PCAS call (see below).
One odd thing I notice.  It seems that GDB finds the debug symbols for
libCom, but not for libcas.  It seems unlikely that this would be true
if both libraries were from the same build.  Also I note that libca is
being loaded from a slightly different path (symlink?).
> Reading symbols from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libCom.so.3.14...done.
> Reading symbols from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libcas.so.3.14...(no debugging symbols found)...done.
> Reading symbols from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base-3.14.12.2/lib/linux-x86_64/libca.so.3.14
This might just be a quirk of GDB searching though.  Can you check on a
running process ("cat /proc/<pid>/maps") to see which libraries were loaded?
Also, running "ldd -v _pcas.so" might be interesting.
FYI I'd recommend setting SHRLIB_VERSION to something more specific than
"3.14".
> Thread 1 (Thread 0x7f8658d49700 (LWP 26265)):
> #0  0x00007f8658933d84 in pthread_cond_wait@@GLIBC_2.3.2 () from /lib/x86_64-linux-gnu/libpthread.so.0
> #1  0x00007f86529ed809 in condWait (mutexId=0x301f080, condId=0x301f0a8) at ../../../src/libCom/osi/os/posix/osdEvent.c:75
> #2  epicsEventWait (pevent=0x301f080) at ../../../src/libCom/osi/os/posix/osdEvent.c:137
> #3  0x00007f86529ec158 in epicsThreadSuspendSelf () at ../../../src/libCom/osi/os/posix/osdThread.c:557
> #4  0x00007f86529e2d05 in cantProceed (msg=<optimized out>) at ../../../src/libCom/misc/cantProceed.c:69
> #5  0x00007f8652568525 in casPVI::getExtServer() const () from /ligo/apps/ubuntu12/epics-3.14.12.2_long/base/lib/linux-x86_64/libcas.so.3.14
> #6  0x00007f8652c2efa3 in PV::postEvent (this=0x30a0200, value=...) at pcaspy/pv.cpp:83
> #7  0x00007f8652c1fdc9 in _wrap_PV_postEvent (args=<optimized out>) at pcaspy/casdef_wrap.cpp:9193
> #8  0x0000000000571b58 in PyEval_EvalFrameEx ()
RE: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Mark Rivers
Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Michael Davidsaver
Prev: Re: EPICS training sessions Bob Gunion
Next: RE: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: "epicsMutex pthread_mutex_unlock failed" with pyepics/pcaspy Jameson Graef Rollins
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
